Results 1 to 9 of 9
    Apr 2017
    Pomona ny
    Dfi oil coming out of exhaust onto cavitation plate
    Optimax 250xs 0t81836. I just changed the air compressor, the tracker valve along with the air and fuel diaphrams. Also had the air and fuel injectors all cleaned and checked after a blown compressor. Now after running on the hose im getting what appears to be fresh dfi oil coming out the port exhaust port onto the cavitation plate. Seems to be a couple ounces each time. Ive been trying to pinpoint an oil leak that pools at the bottom of the pan but oil coming from the exhaust port is completely new
    Attached Thumbnails Attached Thumbnails 20190615_195114.jpg   20190615_195140.jpg
    Aug 2012
    Tenkiller Lake, OK
    Most likely the oil pump. Check the bottom of the pump for oil. Mercury says that the pump is not serviceable, but you can replace the O ring and everything is good. Try searching for this on this site. There is a link to the Bass Boat site there with detailed discussion. I had both pumps start leaking within a week of each other on my 300XS's.
    Apr 2017
    Pomona ny
    Quote Originally Posted by Davidlake View Post
    Yeah i saw a couple threads about the oil pump fix. When i originally changed the compressor i primed the oil pump with the scanner but didnt end up running the motor until a week and a half later. I just ran it on the hose and no oil leak. Im thinking the oil is just the unused oil from before
    Could also be the lower crankcase seal....Looks darker than clean oil from the pump.
    Apr 2017
    Pomona ny
    I'm really hoping its the old oil from the prior priming. Other than minor things the motor has ran strong up until the compressor going but we'll see, I hope to get it back out in the next day or two
    Lower crank seal is no big deal. Worst part is pulling and replacing power head. I seem to get some seal leakage everytime I prime the pumps. It puts a lot of oil in the lower crankcase.
    Apr 2017
    Pomona ny
    Atleast now i know if i get oil consistently from there thats what it is. Thanks
    Feb 2014
    Missouri
    When you prime you also dump a lot out the bleeds, and the compressor drains go straight to the cylinders if the pistons up you will prime out 3-4 table spoons just through the compressor dump lines. Makes a oily mess all through break in
    Apr 2017
    Pomona ny
    Thanks for the info. That confirms what I thought then. This was the first time I primed the oil pump using the ddt
    . I chose that route instead of going thru another break-in. Like you mentioned the amount of oil it goes through and the mess
  1. Releiving the exhaust above the Cavitation plate?
    By 85Sunbird in forum Technical Discussion
    Last Post: 07-10-2003, 10:50 PM
