Results 1 to 8 of 8
Thread: Fuel pump
06-14-2019, 08:00 PM #1Junior Member
- Jun 2019
- Florida
Fuel pump
I have 94 mariner 150hp outboard that when I connect the battery the fuel turns on and does not turn off. What could cause a fuel pump to continuously run? Please help lol.
06-14-2019, 08:15 PM #2Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
A bad ecm or the ground leg is grounded
by a bare wire. Clay
06-14-2019, 08:29 PM #3Junior Member
- Jun 2019
- Florida
Ok thank you. I will try that.
06-14-2019, 08:37 PM #4Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
Btw it would be a good idea to have battery disconnected
while looking for the issue.
06-15-2019, 12:02 PM #5Junior Member
- Jun 2019
- Florida
Thank you. Look like ground is good. I am starting to think ecu. I'm gonna see if I can find a shop that will test it for me.
06-15-2019, 12:34 PM #6Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
On these outboards the ecm controls the fuel pump by
interupting the ground side of pump circuit. The positive
side is always hot. If you can’t get it repaired I have one
off a 1999 175 and a 1996 or so 200.
06-15-2019, 03:41 PM #7Member
- Jun 2012
- Toronto
- 47
I bought a cheap aftermarket replacement pump to replace the pump on my 92 xri 200 (bad idea). The pump looked the same, but when I installed it it was slightly longer than the original and the pump housing touched the block. When I attached the battery, it would run constantly. Obviously makes sense based on the explanation on how the ECM controls it per Tritontr19.
06-15-2019, 04:28 PM #8Junior Member
- Jun 2019
- Florida
I see. Looks like I'm gonna have to get a ecu. Hmm did want to do that. Might just by pass it with a on off switch lol
Rigging Accessories and Parts (Mercury Race Trim Pump, Fuel Pump, Steering, ETC)
By kcoleman10 in forum Misc. Parts and AccessoriesReplies: 7Last Post: 11-26-2013, 08:58 PM -
mallery fuel pump, why does it have a small fitting on bottom of pump?????
By camaro7081 in forum Technical DiscussionReplies: 9Last Post: 05-25-2007, 09:16 PM
