Results 1 to 15 of 29
    Jan 2018
    Alabama
    $400 and 6 Months Wasted! Picked Up My Re-Sleeved Merc 2.0 Today And Was Shocked
    Guys, after waiting for 2 different shops for 6 months and a "special order" LA Sleeve (had to be made super thick), I finally got the call to pick-up my long awaited Merc 2.0L fatblock project block with what was supposed to be a new, sleeved #6 hole.
    How does a long running and locally touted shop get by with this kind of product? Now my project is delayed again while I order a special sleeve and find a new shop. I won't be bolting this together.......Gordon
ID:	441691Click image for larger version.
ID:	441692Click image for larger version.
    Looks about like the xr4 fat block I had years ago. I pulled the heads off and WTF straight from merc it looked just like that. It ran well enough for a ski boat but yeah...
    I use Dwayne Roberie in La. he does my sleeving and bore work on steel and nickel been real pleased and great to work with ...
    Jay
    Jay @ JSRE
  4. Likes tunnelmike, specboatops liked this post
    Dec 2006
    Byron Bay, Australia
    So how thick is the sleeve?
    Jan 2018
    Alabama
    A #6 rod made a mess of the original bore so it needed a thicker sleeve. They don't stock these..... Part # L-04-OB +40 with OD = 3.418"
  7. Thanks gmjim thanked for this post
    Jul 2012
    Lufkin, Texas
    I know fat block 2.0's aren't the most common but I buy old 150's running for $400 and less regularly. Even bought a 175 EFI in pretty good shape for $400. Maybe just find another block?
    Josh Peterson
  9. Likes sonicss33 liked this post
    Pekin, IL
    Why not put it in oven and then properly index sleeve? Unless of course I am missing something else.
    Rock
    Team Junk
  11. Likes FMP, nitro_rat, Capt.Insane-o, JAFFA liked this post
  12. #8
    Jan 2018
    Alabama
    Rock, according to the sleeve guy, the block should have been heated (expanded) and the sleeve left room temperature or less and then pressed in-place with an interference fit (aligned of course). If installed correctly, heating the block with the sleeve in-place as running does, the sleeve expands and will not come out or rotate without some block damage. He recommended boring the sleeve out only and fitting the new/replacement correctly. I have a new, custom make sleeve ordered and should have it before I find a new shop to trust doing the work. Gordon
  13. #9
    I would run the thing before investing another penny in an obsolete block. There is no point in spending another penny. I wish I had pictures of that old xr4. Every sleeve looked like yours and that was untouched from the factory.
    Dec 2001
    Fat block? ya mean 2.5 based 2.0? so they are worth something?
    The sleeve was made with larger ports than what the block was cast with. The first couple years of the fat block that weren't 2.5's were sketchy as hell.
  16. #12
    No, not until some 2.0 f1 sleeves are stuffed in.
  17. Likes nitro_rat, powerabout liked this post
  18. #13
    Pekin, IL
    I have never even heard of someone trying to sleeve a block without heat. If sleeve is installed without heat how is it installed or should I say secured? I put three in a 90 Merc the other day and screwed one of them up. Not as bad as yours but still it was wrong. Back in the oven and rotated it a bit and good to go. Unless sleeve is cast in place I cannot imagine it not coming loose with heat.
    Rock
    Team Junk
  19. Likes keefallan liked this post
  20. #14
    Jan 2018
    Alabama
    Guys, the "why" is not what you'd expect. I do this to keep me busy and enjoyment. I need this 2.0L like another hole in my head - in fact, I don't even have a boat for it yet. I've got 2 vintage Chrysler outboard restorations in-process too. I am a busy-body as my friends say. I can't sit still, don't watch TV, and love working with my hands. I like this block because it was free.....I took it's power trim off for the previous owner and installed that into his Skeeter/XR4 and got the complete 135 SeaRay outboard for my trouble. I realized on teardown that is has very few hours and I was going to make it good again. 5 of the cylinders still have the cross-hatching on them. It died an early death because of #6 seizing when the water pump impeller failed. I found pieces of rubber impeller everywhere. So it's not the cost, not the timing - I wanted something to do.
    I love collecting and enjoy restoring. My garage got full and the wife said I had to find a new hobby.....Gordon
    Right next to the Allison....Click image for larger version.
Name:	CB450 Before May 25, 07 001.jpg
ID:	441789Click image for larger version.
ID:	441790Click image for larger version.
ID:	441791Click image for larger version.
Name:	CL77 Prep and Assembly Jun 24, 10 045.jpg
ID:	441792Click image for larger version.
Name:	GT750 Oct 28, 08 001.jpg
ID:	441793Click image for larger version.
ID:	441794Click image for larger version.
ID:	441795Click image for larger version.
ID:	441796Click image for larger version.
ID:	441797Click image for larger version.
  21. Likes powerabout liked this post
  22. #15
    TX......somewhere?
    tha XR4 merc sleeve's were like that from tha get go ('87 up)…. their first attempt atta steel 2.4..
  1. I saw something today that shocked me. Really.
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 08-25-2016, 07:27 AM
  2. Picked up TWO Vipers Today
    By wireless in forum General Boating Discussion
    Last Post: 07-13-2010, 06:39 PM
  3. Venom Picked up today!
    By Stream 1 in forum General Boating Discussion
    Last Post: 12-25-2005, 10:36 AM
  4. Picked up 700 RPM's today !
    By BOUDREAUX in forum Technical Discussion
    Last Post: 12-02-2003, 09:57 PM
  5. Picked up a 1986 3.4 300 today!
    By Vicious One in forum General Boating Discussion
    Last Post: 09-17-2003, 05:05 PM
