Results 1 to 8 of 8
06-13-2019, 08:11 PM #15000 RPM
- Sep 2009
- Miami
- 357
Mercury 4500 Gen II throttle spacer
Is there a spacer made to provide clearance for a Mercury throttle. My throttle hits the gps at full throttle. Need about 1/2 clearance added to console to eliminate.
TIA
Tom
06-13-2019, 09:22 PM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Yep. I cam check on the part number tomorrow. Just in installed one today
06-13-2019, 09:34 PM #35000 RPM
- Sep 2009
- Miami
- 357
Thanks
T
06-13-2019, 09:52 PM #46000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
The spacer is pretty thick. If I only need
5 to .75" I toss the base on some starboard and trace it out with a router
06-21-2019, 09:00 AM #55000 RPM
- Sep 2009
- Miami
- 357
Does the Mercury throttle truly go all the way down when at full throttle? meaning, if my gps is mounted with 1/2 inch sticking out above the console will the throttle hit the screen or does it stop an inch or so above the console? Is there an adjustment to limit the forward travel of the throttle while still allowing the throttle to fully engage the carbs on the motor?
Tom
06-21-2019, 12:09 PM #6
Are those handles splined onto the shaft to allow you to reposition it slightly, possibly loosing some reverse throttle but giving you clearance at WOT
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
06-21-2019, 02:26 PM #76000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
06-21-2019, 02:26 PM #86000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Mercury spacer
By ahead of u in forum Parts WantedReplies: 0Last Post: 08-25-2017, 09:31 AM -
Throttle rod for 260 with 1 inch spacer
By Laser LTV in forum Parts WantedReplies: 25Last Post: 12-06-2013, 07:53 PM -
Throttle Body Spacer
By Creed Poole in forum Tow Vehicles and TrailersReplies: 2Last Post: 12-04-2004, 01:03 AM
