Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 63
    Mar 2017
    Miami, FL
    Mercs 150 4s is 456#'s. The more I run one the more I like them. Friend has one on his 20' Lake and bay flats. Goes 50 or so and planes instantly. Fuel economy is still not as good as a v-6 opti. And is heavier by a few #'s. The 175 is 470#'s.
    That 150 merc is an awesome motor, I thought about one for my L&B hull, there are some good deals on used ones.
    This etec is intriguing, I wonder what the RAVE could do for other models, wonder if it'll give any issues
  2. Likes WavetoWave liked this post
  3. #17
    115 triple, 150 triple. Able to have higher ex ports without loss of bottom end by using a valve which maintains an ideal amount of duration based on running rpm. Drops the port roof at low rpm to maintain desired optimum port to port blowdown pulse arrival delay, then raises it to achieve high rpm power. Overall duration at high rpm can be raised without detrimental effects to the rpm climb under load from low rpm because of the change in duration effect.
  4. Likes Whaaaaat, loop liked this post
  5. #18
    Sep 2017
    Miami
    The 3 cyl 150 replaces the regular 2.6 etec V6 150 and the V6 2.7L 150 and 150 HO remain, making 3 different 150s. I could be wrong on that. The claim is it will be the lightest 150 in class by over 50 Lbs, which puts it around 390. Gear ratio for the 115, 140 and 150 is 2.08, from what I hear. Keep in mind, the 3 cyl has the iSteer optional, which greatly affects weight.
    Standard color is black, with red swoosh. The new white motors come standard with silver swoosh. Custom panels extra. All the G2's now come in that white exoskeleton color and revised panels.
    Dyno
    [url=https://flic.kr/p/2gdFPba]
    White
    [url=https://flic.kr/p/2gdFP9B]
    Family Photo
    [url=https://flic.kr/p/2gdG4jn]
  6. Thanks Scream And Fly thanked for this post
    Likes Whaaaaat, FMP, loop, Scream And Fly liked this post
  7. #19
    PARADISE /Naples
    Thumbs up
  8. #20
    The 150 curve is likely higher still at the low end and where the 115 flattens the 150 maintains the climb.
    What would be fun is to really see what they could get from it. No EPA regulations, just limited by premium pump gas and still maintain a useful low rpm range power. Higher duration still, more compression, more ign , more fuel. I bet close to 190 at the crank! Even at 150 prop , she's detuned reliable.
  9. Likes WavetoWave liked this post
  10. #21
    Sep 2017
    Miami
    Ya, in that chart, the Merc would be able to rev higher to 6300, rev limiter might be 6400?, and might make more power up there.
  11. #22
    Sep 2017
    Miami
  12. Likes aeneas liked this post
  13. #23
    Been there with that proxs115 , doesn't do anything at 6200 it isn't doing at 6000 except bounce the alarm. I'm sure the 'Rude was tuned for the lead and win on the same hull, I mean wouldn't you!
    Wow,
    Long stroke, Bore x Stroke - in (mm) 3.85 x 3.25 (98 x 82.6)
    I figured 4.0125"x 3.0" , Doesn't need to spin the extra.
  14. #24
    Sep 2017
    Miami
    The four stroke ProXS? Should cut out around 6400. It's operating range is to 6300, usually there is 1 or 200 grace.
  15. #25
    Yes, the PROXS with the small case. Limp biscuit, going to need a head to head to find out the Merc sucks.
    Trolls wonderfully quiet can't complain except it couldn't break 34 mph with 3 people no gear and 38-39 with two people going with the 1 1/2' chop at 6300 trimming for miles to get it there, different props didn't help. Lund 18' new boat.
    Would take this one without hesitation over the proXS four
    https://www.screamandfly.com/showthr...32#post3140632
  16. #26
    Never thought I would say that the new e-rude in not uglier than the new merc. They are about equal. I thought I would get used to and start to like them. But nooooo....Just can't...
    Sarasota, FL
    no oil change ever? Hows that?
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  18. #28
    it's a 2 stroke......
  19. Likes FMP, keefallan liked this post
  20. #29
    Ha!
  21. #30
    With all the back and forth it's easy to forget that someone still makes a 2 smoke.... I admire BRP for sticking with it.
  22. Likes David - WI, WavetoWave, 22R, aeneas, keefallan liked this post
  1. Article: Evinrude Launches New 3-Cylinder E-TEC G2 Outboards
    By Scream And Fly in forum vBCms Comments
    Last Post: 07-20-2019, 08:37 AM
