Results 1 to 10 of 10
Thread: Re-powering my Mercury 2.4 200
06-09-2019, 12:43 PM #1Junior Member
- Mar 2017
- Gilbert, AZ
- 13
I have a 1989 Mercury 2.4 200 black max carb. The boat is a 1990 caliber 1 202 stinger with a mod vp hull. I want to re-power but don't want to have to buy a "complete" motor (cowling, etc). What could I get that would fit under the existing cowling? Would you recommend EFI over carb? I hit 70 mph last weekend but would like to be in the 80's. Thanks in advance for the help!
06-09-2019, 02:00 PM #2
Any 2.5 will fit under your existing cowl. I like carbs because I'm a cheap bastard but EFI is nice. I would look for a 225 promax with the plate and tuner. It will go on your leg with your cowl. EFI and reliable power. Just delete the oil injection and premix.
Josh Peterson
W2F a V-King, Baker343 liked this post
06-09-2019, 02:18 PM #3
That's if hes up to the challenge of fabin it to fit , not everyone fans the 2.4 clam to a 2.5 Haha. But sure would b a sleeper with a promax
nitro_rat liked this post
06-09-2019, 02:35 PM #4
06-09-2019, 02:43 PM #5
Hell that's a drag cowl n pic. Just go get u a 2.5 ov sumsort with tuner and exhaust plates and u ready
06-09-2019, 02:54 PM #6
W2F a V-King liked this post
06-09-2019, 03:30 PM #7Junior Member
- Mar 2017
- Gilbert, AZ
- 13
nitro_rat thanked for this post
06-09-2019, 04:39 PM #8
If I remember right Caliber 1 purchased Bakers 20ft bottom mold after Jerry past and they designed their own deck.
The Baker 20 was a solid boat just not as fast as his 18.6
80mph and north is a challenging number to achieve especially with full interior, saddle tanks and if you want to entertain family and friends with the ski pole. A steel sleeved modified 2.5 fishing motor or a Promax could get you there with some testing. A good LU and a worked bow lifting prop will help and I would try to keep the cooling system stock.
If your going to tested with someone in the boat have them sit opposite of you in the back seat. I had a 18.6 Baker ski boat with a carbed 2.4 seven pedal 225 with no oil injection. It took a lot of work and testing to hit 80 and above. Good luck
06-09-2019, 08:42 PM #9Junior Member
- Mar 2017
- Gilbert, AZ
- 13
06-09-2019, 08:56 PM #10
A 260 uses a one piece plate and i'm not sure your cowl brackets will bolt to it, I've never had one. You'll likely need a "race" style lightweight cowl to go with it. I'm sure it's possible to use a 2 piece plate with a 260 but it will require modifications to the plate. Somebody else has probably done it and might could point you in the right direction if that's the way you want to go...
Josh Peterson
Photos: Mercury Racing 300R powering Bullet 21SST and Bass Cat at Lake X
By Scream And Fly in forum General Boating DiscussionReplies: 11Last Post: 07-20-2018, 10:40 AM -
If it's worth powering, its worth Over Powering... what Engine would you run??
By Pachanga_rick in forum General Boating DiscussionReplies: 51Last Post: 06-07-2017, 10:21 AM -
re-powering
By overdue in forum Technical DiscussionReplies: 2Last Post: 09-14-2016, 10:45 PM -
Mercury 150 not powering up
By HarleyG8r in forum Technical DiscussionReplies: 7Last Post: 07-29-2011, 06:28 PM -
Re-powering
By TonyBal in forum Technical DiscussionReplies: 5Last Post: 02-02-2009, 05:43 PM
