Page 8 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 106 to 120 of 252
  1. #106
    Shreveport, La.
    [QUOTE]
    Maybe will see you and your son next year.
    Hope so. You never know.
  2. #107
    No War Canoe....no enduro
  3. #108
    Shreveport, La.
    I agree Capt.
  4. #109
    The original or the current hull?
  5. #110
    May 2013
    Huntiington Beach Ca
    What I had intended to do on a couple motors I have without the big bearing up top was to use an oil injection tank to feed the upper and center mains just via from pressure from the crankcase. I ran a couple half race distances here and had it mostly sorted out and it worked well. Took a little bit to get the flows restricted right to where a full tank of oil would last a fuel run. But the rules mongers came about and meh...
    Interesting. Was your thinking to add extra oil because you intended to run your motor above a certain RPM's for the Enduro.
    Don't see how Mr Chopper would have shot that one down. Don't see it being a issue for the current rules committee, which again I'm not part of.
    Above what RPM's do you think would benefit from this.
    Would a 7 pedal, EFI, behind the liner 2.4 fat block running 6800-7200 possibly benefit from this modification.
  6. #111
    I was set up to run 8-8500. The way the math figured out was about 18:1 running 50:1 in the tank,, the extra oil filtered down from the top main to 1 and 2, top center main for 3 and 4 and lower center main 5 and 6 the lower main bleed line I ran back to the vent hose to the fuel tank.
  7. Thanks Baker343 thanked for this post
  8. #112
    May 2013
    80's Parker 9hr Enduro fuel stop
    20 Baker Rampage driven by John Soares.
    Probably didn't see to many Suzuki's back then
Name:	D2 Baker.jpg
  9. Likes Tango liked this post
  10. #113
    Florence, SC
    Quote Originally Posted by Baker343 View Post
    Mid 80's Parker 9hr Enduro fuel stop
Name:	D2 Baker.jpg
    That's a sick looking boat!!!
  11. #114
    Definitely not many Suzuki boats in the 80s. Heck, Yamaha was just beginning to get their foothold back then. Cool pic.
  12. #115
    Shreveport, La.
    We ran the Yamaha 225 Excel and it was a great motor. Tough as nails. The Suki however was not. The bolt on cylinder jugs just were not strong enough.
  13. #116
    May 2013
  14. Likes AZMIDLYF, Frank Molé liked this post
  15. #117
  16. Thanks Baker343 thanked for this post
    Likes Frank Molé liked this post
  17. #118
    Sep 2017
    Ashland city tn
    I know this has been asked b4 and I'm by no means a inboard guy but seems like that would b the ticket to finish the race ,, or they just fall apart worse than the o/b?
  18. #119
    Florence, SC
    Quote Originally Posted by Merc 2.5 View Post
    Build a v-bottom with a v8 and your rules are free. Just try to figure out how to keep it alive at 100mph avg and only stop twice for fuel.
  19. #120
    I watched this beauty run around like a clock for hours only to quit right before the end...they seem to pull up lame after a couple hours.
  1. Upcoming Event: 2017 Parker Enduro
    By Baker343 in forum General Boating Discussion
    Last Post: 12-01-2017, 07:37 AM
  2. Parker enduro
    By AZMIDLYF in forum Upcoming Events, Races, and Gatherings
    Last Post: 10-28-2017, 02:28 PM
  3. Parker 300 Enduro
    By frankydee in forum Technical Discussion
    Last Post: 11-02-2013, 05:47 AM
  4. Parker enduro 1975 vid
    By Marko in forum Outboard and Racing History
    Last Post: 06-30-2011, 10:46 PM
  5. Parker / Bluewater 300 Enduro
    By superdave013 in forum General Boating Discussion
    Last Post: 10-01-2005, 11:05 AM
