Page 7 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 91 to 105 of 252
  1. #91
    Jan 2003
    LA, CA
    Anybody know where I can find the current V-bottom Outboard Ski Race rules for their hull/motor set ups?
    This should get interesting.
  2. #92
    SOCAL
    AZMIDLYF, you can find the rules here. http://www.nwsra.net/rules-and-membership.html
  3. Thanks Baker343 thanked for this post
    Likes AZMIDLYF liked this post
  4. #93
    Jul 2002
    Las Vegas, NV
    Quote Originally Posted by Mad Maximillion View Post
    I think he was asking about the Parker Enduro rules for the ski-race boats (Division III). If so, those rules are here: https://img1.wsimg.com/blobby/go/a85...=1568060585413
    Keith-
  5. Thanks Baker343 thanked for this post
  6. #94
    Well, the Parker rules for a V bottom outboard in the Ski Race class states to use the sanction's rules for that class. So I wanted to see what exactly those were.
  7. Thanks Mad Maximillion thanked for this post
  8. #95
    May 2013
    Huntiington Beach Ca
    If this doesn't help you can contact Ross rpmracingent@yahoo.com or 310 318-4012 to help clarify or put you in contact with someone from the
    national water ski racing association.
  9. Likes AZMIDLYF liked this post
  10. #96
    May 2013
    Motor is coming together. Hope to get some hours on it this weekend.
ID:	448611Click image for larger version.
  11. Likes AZMIDLYF, Merc 2.5 liked this post
  12. #97
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Baker343 View Post
    What has perry done to it this time , still the 2.4?
    "Edit" guess so. See ports n pistons
  13. #98
    Florence, SC
    https://www.catalinaskirace.net/rules/
  14. #99
    May 2013
    Little 2.4 fat block with a little this and that. We'll see what James created.
    Trying to run 1400lbs dry class
  15. Likes AZMIDLYF, Merc 2.5 liked this post
  16. #100
    Shreveport, La.
    So what class is that at Parker?
    OK I just read the rules for your 2.4 and it looks good but if I were to run that class I would have to run a drag motor at the same weight you have to run. You may have more of a chance to actually finish the race tho.
  17. #101
    May 2013
    Bull, yes we will be running in the division VI which allows 2.4 unlimited porting with restrictions on compression and must be a minimum 1400lbs without driver and fuel.
    Div VI also allows 2.5 unlimited porting with restrictions on compression and a minimum 1500lbs without driver and fuel.
    And yes this class is required to run the prop shaft 1" below the bottom.
    You may have not heard from last years race but Foster lost the back of his boat as it started to walk to the right
    and he survived a nasty ejection at 95 plus mph. Unsure if it had a pencil roll ( I think its call to the center sponson).
    Were trying to run upper 80's in the beginning and MAYBE low 90's if the water calms. 300 drag would be great but we cant afford that DBR 350hp monster which is probably spinning close to 8 grand for four hours. James has put a lot of work into our 2.4 to make it competitive and to remain at 1400 lbs which we feel is safer for us. Our choice.
    We are going to test props that create whole boat lift and bite like a BBlaster or Eagle 4 and when your short on HP and funds its hard to spin a big wheel to achieve the big end numbers. We want to run around 6800-7000 rpms to help our motor survive.
    I know you remember many start and many wont finish. Doesn't matter what you bring to race.
  18. Likes AZMIDLYF liked this post
  19. #102
    What I had intended to do on a couple motors I have without the big bearing up top was to use an oil injection tank to feed the upper and center mains just via from pressure from the crankcase. I ran a couple half race distances here and had it mostly sorted out and it worked well. Took a little bit to get the flows restricted right to where a full tank of oil would last a fuel run. But the rules mongers came about and meh...
  20. Thanks nitro_rat thanked for this post
    Likes nitro_rat liked this post
  21. #103
    Shreveport, La.
    Baker, I fully understand the pains of low funding. Yes I heard about Fosters ride. He got lucky. Also in reading the rules I didn`t see anything that say`s you can`t run a 2.4 Bridge Port. I have a carbed one on my Riot and two more in the shop ready to go. One is crankcase injected. Some day I`ll figure out a good use for them.
    Capt, That's a great idea. I can`t see where the rules makers would have a problem with that.
  22. #104
    Florence, SC
    Quote Originally Posted by Da Bull View Post
    Wait a sec... I have an App for that!
  23. #105
    May 2013
    Bridge Port would be fun. We tried to contest with a Mod-vp last year but missed on the jetting and windowed the block a few laps in. That one hurt after months of prep and testing.
    Maybe will see you and your son next year.
  1. Upcoming Event: 2017 Parker Enduro
    By Baker343 in forum General Boating Discussion
    Last Post: 12-01-2017, 07:37 AM
  2. Parker enduro
    By AZMIDLYF in forum Upcoming Events, Races, and Gatherings
    Last Post: 10-28-2017, 02:28 PM
  3. Parker 300 Enduro
    By frankydee in forum Technical Discussion
    Last Post: 11-02-2013, 05:47 AM
  4. Parker enduro 1975 vid
    By Marko in forum Outboard and Racing History
    Last Post: 06-30-2011, 10:46 PM
  5. Parker / Bluewater 300 Enduro
    By superdave013 in forum General Boating Discussion
    Last Post: 10-01-2005, 11:05 AM
