Results 16 to 30 of 44
Thread: Prop to pad Explanation
06-07-2019, 08:01 PM #16The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
06-07-2019, 08:02 PM #17The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
06-07-2019, 08:04 PM #18The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
06-08-2019, 11:56 AM #19Member
- Jan 2018
- Florida
- 97
06-08-2019, 03:08 PM #20
Not close to the same set up, but I was going to do tempest's on my 31 twin cc then I called BBlades. Raised my motors up 1 notch. Went from offshore series 4 blade 22p @5800 62 mph to 24p BBlade o/b series 5800 69-70 mph 1in dia larger prop. Worth looking at. they are a little pricey..
06-09-2019, 05:13 AM #21
06-09-2019, 08:49 AM #22
I also gained big in the mid-range cruise. 4000 rpm 43-45 mph depending on amount of fuel im carrying.
06-09-2019, 10:55 AM #235000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
What’s the name of the guy who did your cone?
06-09-2019, 12:06 PM #24Member
- Jan 2018
- Florida
- 97
Update!!
Disclamer:: i was running in a fresh water canal with just me on board and about 20gallons of gas.
24 tempest plus, jack plate raised to 4 with positive engine trim, 5800 rpms 58mph. Blowing a real nice rooster tail, However, steering is extremly tight, i experienced this with the other props i tried last weekend with the jack plate that high as well.
i also didnt get much bow lift that i could tell.
just for compairison i put my 19p mirage plus back on. Boat jumps on plane in seconds. Jack plate up at 2 with slight positive trim 57mph at 5800~5900rpms, i have to be carefull with this prop as i can go past max rpms if im not paying attention. Much better bow lift. No rooster tail at all. And steering is soft as silk.
06-09-2019, 12:11 PM #25Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
That's good for that 2020. They are designed to plane fast and run flat. You have a lot of wetted surface.
06-09-2019, 01:42 PM #26Member
- Jan 2018
- Florida
- 97
06-09-2019, 01:51 PM #27
Try a Trophy.
06-09-2019, 01:52 PM #28
prop slip is a factor. this will lower speed/increase rpm's. also not all props run true to pitch number so you 19 could measure 20 or 21 and your 24 could measure 23 or 22. If the props are of unknown provenance they could have been worked to a different pitch in the past and not marked...
slip is probably the main factor in your case.Josh Peterson
06-09-2019, 02:41 PM #295000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Sounds like you’re running good with the mirage. Maybe try the next pitch up. The tempest with the jackplate higher and trimmed up is probably just slipping. When you drop it in the water to about the same level as the mirage, how fast are you running and at what rpm?
06-09-2019, 04:41 PM #30Member
- Jan 2018
- Florida
- 97
Obamanomics - Texas Explanation
By Rocket in forum The Scream And Fly LoungeReplies: 2Last Post: 02-10-2010, 10:04 PM -
Damn Fine Explanation
By mirage243 in forum The Scream And Fly LoungeReplies: 4Last Post: 11-01-2009, 12:19 AM -
Pad-V experts, need an explanation.
By Georgia Boy in forum General Boating DiscussionReplies: 9Last Post: 07-08-2003, 12:33 AM -
2.5 pistons--explanation
By B. Vruwink in forum Technical DiscussionReplies: 1Last Post: 11-14-2002, 01:29 AM -
STV---Need explanation
By B. Vruwink in forum General Boating DiscussionReplies: 2Last Post: 06-10-2002, 09:04 AM
