Results 1 to 5 of 5
    Nov 2008
    260 HP Stock 2.5 Powerhead on Offshore mid and rebuilt powerhead - Local P/U only
    For local purchase only in Southern California, Lake Havasu City, AZ, or someplace in between.
    Selling a stock 2.5 260 HP powerhead with low hours (under 100 hours). Only draw back is it still has stock "side" pinned pistons and possible issue with ECU. This is sitting on a excellent condition 20" Offshore Mid.
    $6,500.00 ($4,000 for powerhead, $2,000 for mid, and $500 for cowling and Pan) - Prefer not to separate.
    Also selling a rebuilt powerhead, top pinned pistons, but block has been professionally repaired and welded. This powerhead is at DBR in Lake Havasu but I can bring back to So Cal if interested.
    Thank you,
    Colby
    ampcolby@gmail.com
    Sep 2008
    Arkansas
    Did this sale. Yr model what makes you think ecu bad thanks Robert
    Nov 2008
    Hello Robert
    I will find out year. I. Ought from a straightforward guy who ran it and showed condition of pistons and cylinder walls. Runs great but he seems pretty sure map sensor is bad. It’s a great piece and very clean. I would like to keep for a project but have a lot of work to do on it before putting any power on it
    thanks
    Colby
    May 2017
    Ca
    Hey Colby this is Blake the guy you bought it from. The motors a 96’. I sent the ecu to Brucato and he tested it and it had a bad map sensor. Other then that the motor is super solid. Good luck the sale! Wish I coulda seen it on that gmt though!
  5. Likes gqchris liked this post
    Nov 2008
    Hey Blake,
    Thank you for responding with that information - Hope all is well. Maybe see you on the water soon.
  1. Mercury 2.0 powerhead needs rebuilt
    By Keaten in forum Outboard Engines
    Last Post: 10-27-2017, 11:24 AM
  2. rebuilt powerhead
    By team supra in forum Technical Discussion
    Last Post: 08-14-2012, 04:09 PM
  3. Yamaha Tech: rebuilt 250 vmax powerhead won't run.
    By SKIFFY123 in forum Technical Discussion
    Last Post: 03-03-2009, 04:46 PM
  4. Rebuilt powerhead...TEMPERATURE???
    By Dave Estes in forum Technical Discussion
    Last Post: 06-30-2001, 01:18 PM
