Results 1 to 4 of 4
Thread: Prop trouble
    thowell327 Guest
    Prop trouble
    Hey guys, im not sure if any of you are familiar with the setup, but i have a 21 mtr cougar with a 2003 300x hanging off the back. The boat is awesome, and handles great, but i have only taken it to the lake one time so far. The previous owner gave me two props. One is a 28p 4 blade signature prop, and the other is a 34 three blade mercury cleaver prop. The 34 was on it during my lake run, and with just me in the boat it cavitates really bad which i understand is normal with that high of a pitch prop. Alot of my boating will be with a fairly full boat so that just wont work for me. This is where im lost. The previous owner told me with the 4 blade on there, and he told me this multiple times, do not go over 60 with this prop on because when you let off it gets scary. Id love to have a prop where i can get out of the hull with a full boat and still do close to 90... i never have felt this scary feeling but i sure dont want to try it with friends and family in the boat or put myself in danger.. anyone know what hes referring to?
    Try a Lightning ET, Cougars run well with them.
  3. Likes rock liked this post
    Pekin, IL
    Dave is correct. We had one with a 260 (I know it's a bit lighter than a 3.0) that was modified to the max and pushed the boat to 113 with a 30 ET. We tried a couple REs both 4 and 3 blade and no contest. The ET was best. The 4 blade you are cautious about probably sets the boat back in the water a little quicker than the 3 blade and when coming off plane you really want it to land straight. Can't imagine an issue at 60 mph but who knows. I have had STVs over 120 many times and shutting them down requires a lot more attention than just driving in a straight line does. Good luck.
    Rock
    Team Junk
  5. Likes Dave Strong, Baker343 liked this post
    thowell327 Guest
    Quote Originally Posted by Dave Strong View Post
    awesome ill try it thank you!!!
  7. Likes Dave Strong liked this post
  1. Trouble with OSO
    By CMC in forum The Scream And Fly Lounge
    Last Post: 11-12-2007, 11:41 AM
  2. Replies: 6
    Last Post: 07-06-2005, 07:59 PM
  3. merc/trouble......changed prop......
    By OIDALE in forum Technical Discussion
    Last Post: 10-27-2004, 07:28 PM
  4. merc/trouble, works better.....maybe prop
    Last Post: 10-17-2004, 10:25 AM
  5. sometimes low rpm trouble
    By Diane in forum Technical Discussion
    Last Post: 06-23-2004, 10:38 PM
