Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Mar 2009
    Port Saint Lucie
    I/O to bracket conversion
    So this isn't a speed boat, but it's a conversion none the less. Boat is not rotten, so we just patched outdrive hole and added knees for a little extra. The deck will be filled in and a bulkhead all the way across the back of the transom. Not many pics of the process. I cut 14 inches of stringer out, was rotten due to drain holes drilled in the wood. I stripped back 1 layer of ply wood for the patch. I screwed a board to the outside of the boat and skinned the repair. Couple extra mats in the middle. After it was cured I wet 2 mats and puttied in a board the size of the hole, then putted in a board the size of the cutout. 2 layers of 1708 over it. Built knees and puttied them into the stringers, with 1 extra filler piece of wood. Glassed over the face of the knees and let it cure. After it was all cleaned up, I glassed the knees into the boat and glassed 24 inches of the stringer into the boat. The whole transom got a 1708 covering all the tabs. The drain holes now have pipes in them and no exposed wood. When that was done, I got to get dressed up in long pants and shirt, hat, glasses and dust mask and grind all of it. It needs gel coat and the rest of the pieces installed.
    Attached Thumbnails Attached Thumbnails 20190516_145215.jpg   20190515_151130.jpg   20190515_151114.jpg   20190515_100805.jpg
  2. Likes TwzteD, NAVISPEED1 liked this post
    Mar 2009
    Port Saint Lucie
    Attached Thumbnails Attached Thumbnails 20190521_141731.jpg   20190521_141726.jpg   20190521_131326.jpg   20190521_131254.jpg   20190521_103550.jpg
  4. Likes TwzteD liked this post
  5. #3
    Mar 2009
    Port Saint Lucie
    Attached Thumbnails Attached Thumbnails 20190528_122820.jpg   20190528_122740.jpg   20190528_122703.jpg
  6. Likes tnelsmn liked this post
  7. #4
    Mar 2009
    Port Saint Lucie
    Last pics are all washed out and cleaned up.
    Attached Thumbnails Attached Thumbnails 20190529_152127.jpg   20190529_152040.jpg   20190529_150757.jpg
  8. Likes tnelsmn liked this post
  9. #5
    Mar 2009
    Port Saint Lucie
    Attached Thumbnails Attached Thumbnails 20190516_145158.jpg   20190516_145146.jpg
  10. Likes TwzteD liked this post
  11. #6
    Sep 2011
    maryland
    Looks good.
  12. #7
    Mar 2009
    Port Saint Lucie
    Nothing to crazy. Only wood because the rest is. But not rotten so will be good for a long time. Was done in 2012 I think. Just patching it up.
  13. #8
    Mar 2016
    cincinnati, ohio
    What kind of boat, what engine is going on it, any pics????
  14. #9
    Mar 2009
    Port Saint Lucie
    I'll have to get back with specifics. But I think it's a formula center console. 400hp I think.
  15. #10
    Mar 2009
    Port Saint Lucie
    It's a 23 formula getting a bracket and Merc 400.
  16. #11
    Wow that should be a cool old boat. Those formula's were great in the ruff for a 23'er. Might touch 60....
  17. Likes Will hedrick liked this post
  18. #12
    Oct 2018
    Tennessee
    A lot of people don't realize how much goes into a transom repair, nice job bud
    (Rip. Whiteally02) -dad
  19. #13
    Mar 2009
    Port Saint Lucie
    And its only a patch. Still gonna add a couple pieces of ply across the top of the transom. There is only wood in the middle. Add extra strength to the upper transom and corners.
  20. #14
    Mar 2009
    Port Saint Lucie
    So did a little bagging. Scored the ply on the back so it would bend, putted it in and pulled it down. It pretty much squished out everywhere. Yes the middle is a shop vac, it was only to hold it in place. It was flat and fit right, just needed vacuum to hold it down for 20 min.
    Attached Thumbnails Attached Thumbnails 20190605_143218.jpg   20190605_143212.jpg   20190605_143215.jpg
  21. Likes noli liked this post
  22. #15
    Mar 2009
    Port Saint Lucie
    Filled any gaps and drug some putty around the edges. It'll all get sanded smoother and glassed.
    Attached Thumbnails Attached Thumbnails 20190605_153611.jpg   20190605_153606.jpg   20190605_153602.jpg
  1. oem mercury ecu bracket and brucato ecu bracket 260/drag style
    By kyja95 in forum Misc. Parts and Accessories
    Last Post: 12-11-2018, 05:05 PM
  2. Mercury Tech: help with 2.5 offshore clamp bracket swivel bracket assembly
    By davidmercury in forum Technical Discussion
    Last Post: 05-04-2011, 06:59 AM
