Results 1 to 7 of 7
    Apr 2006
    Englewood FL
    235 hp heads for a 1986 evinrude or 2 water jacket covers for heads
    Looking for a set of heads for a 235hp evinrude from 1985. Or any good replacements with high compression. Both heads had cracked waterjacket covers so maybe I can just replace those if anyone has them available.
    Replaced heads. Thanks All
    Callahan, FL
    I think I can help you out with a set of stock 235 heads, I will get head numbers and pictures too you this weekend..
    Jeff
    #12 Miller American SST 140 Tunnel hull
    1970 Glastron Carlson CT-15, Merc 1350
    1977 Hydrostream Ventura II Comp, under construction. Have 1500xs waiting.
    Callahan, FL
    Here Are the picture of the stock 235 hp heads I have, numbers are 328326, 328327. And as you can see # 3 cylinder broke a piston ring and as a result has a little damage to the head, should not cause any problems. These were only run in fresh water, no salt ever.
    Sent you a PM. Jeff
ID:	440446Click image for larger version.
    Jan 2008
    SUMMERVILLE S.C.
    there wasn't a 235 in 1986...first year for the looper...do you need 225 looper heads or old crossflow heads?
    Apr 2006
    Englewood FL
    It must be a 1985 crossflow my bad.
    Apr 2006
    Englewood FL
    What u asking for the heads shipped to cape coral fl
    Callahan, FL
    Just sent you a PM
  1. !985 Evinrude 120 heads
    By SS Minnow in forum Technical Discussion
    Last Post: 06-06-2018, 07:00 AM
  2. 1986 OMC parts reference. 2.7L carbs and heads
    By bigshrimpin in forum Technical Discussion
    Last Post: 12-04-2008, 09:31 PM
