Results 16 to 27 of 27
Thread: Foil for talon 18
06-02-2019, 10:43 AM #16
Before i started this post i spent a bunch of time searching foils and the general consensus was that the thick cast foils were cavitation plate brakers. Im running a motor that lacks in the low end department and being on a heavier boat the holeshot pretty much sucks. I did put a skid plane on last year and it did help out quite a bit but looking to improve it a little more. So far it sounds like the allison plate may be the ticket but kinda surprised no comments on the mike ray foil, must be more for a drag racing application
06-02-2019, 11:00 AM #17
https://www.screamandfly.com/showthr...ary-Afterplane
Yeah they work well but you said your low on power, so it might be too much for your application, add a little compression that helps the bottom endWe have invented the world; WE see
06-02-2019, 11:15 AM #18
A compression increases on this motor has been on my list of things to do. Any advice on a cc to make around 150 lbs on a bridgeport?
06-02-2019, 11:23 AM #19
Try Jay Smith, or someone that does outboard machine work, what is your cold cranking compression?
It's easy to set up 24 volt starting circuit also, just need a small battery because you need Volts not ampsWe have invented the world; WE see
06-02-2019, 11:48 AM #20
Not sure what cold is but after warmed up it was between 132 and 135 and i cant find my notes on what i recorded on leakdown last year before i put it up last year.
06-02-2019, 11:53 AM #21
06-02-2019, 12:03 PM #22
Geiger Tech is making one similar to Mikes I think
06-02-2019, 12:15 PM #23
Yup when i did the rebuild on the bridgeport i did cut the heads. Wanna say they are at 34cc now. Was going to use a set of 2 liter heads. Have heared it will get compression to 150 but also heard the squish clearance wont be correct
06-02-2019, 01:01 PM #24
Not sure bout squish but Ive heard plenty doin it ,, u could safely go to 32cc, maybe even 31. But rather b on safe side at 32 ,then take ur pic of foil
06-02-2019, 01:16 PM #25
In DSRA/ODBA they let you run 26cc heads on a stock 260 and 300 Drags must run stock compression 36ish ?
and that little difference evens things out pretty goodWe have invented the world; WE see
06-04-2019, 06:33 PM #26
Thank you everyone for chiming in and offering advise. Im leaning towards a allison foil. I went to the allison site to find out a price but couldn't find the foils. Is there someone here that sells them
06-04-2019, 07:50 PM #27
Ill get those blocks out friday if you still want them too.
2019 Talon Powerboats "Talon Turnout" Event
By Talon-Powerboats in forum General Boating DiscussionReplies: 50Last Post: 10-05-2019, 09:21 AM -
Foil
By Rideau Bullet in forum Misc. Parts and AccessoriesReplies: 6Last Post: 03-12-2019, 12:30 PM -
ET Foil/ Hydra Foil
By tomoad in forum Technical DiscussionReplies: 0Last Post: 02-02-2006, 07:38 PM
