Results 1 to 6 of 6
Thread: Optimax oil line routing
05-26-2019, 06:52 AM #1Member
- Aug 2017
- Wisconsin
- 33
- 22
2012 Mercury Optimax Pro XS serial number 1B865804
I'm in the process of putting motor on, I’m wondering if anyone has a picture of where the oil line plugs into block? My old motor was an EFI. Thanks
05-26-2019, 09:11 PM #25000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Should definitely get yourself a service manual. Invaluable source of info
05-26-2019, 10:01 PM #3
The pulse air port is in the same location as your old engine as is the oil hose hookup......
Bass man liked this post
05-27-2019, 12:33 AM #4
Blue strip hose connects to the brass tee fitting that is hang from small oil tank on motor. The unused nipple on the tee fitting looks like it should be connected to something but it does not. Your solid black hose from your remote oil tank connects to the pulse check valve that is hid behind the oil pump lines and the rigging 10 pin connector wires.
05-27-2019, 07:06 AM #5Member
- Aug 2017
- Wisconsin
- 33
- 22
Thanks. I figured that was it, at the same time I thought the guy told me he had nothing attached there.
05-27-2019, 07:12 AM #6Member
- Aug 2017
- Wisconsin
- 33
- 22
Fuel Line/Bleed Line Routing for '96 2.5 200EFI
By Hydrasports205 in forum Technical DiscussionReplies: 2Last Post: 09-11-2017, 11:08 PM -
OMC Tech: Line Routing
By low tide in forum Technical DiscussionReplies: 2Last Post: 07-24-2011, 08:07 AM -
Mercury Tech: Bleed line routing...help!!!
By motorheadbishop in forum Technical DiscussionReplies: 5Last Post: 04-15-2009, 10:31 PM -
cooling line routing
By paul2112 in forum Jet Boats, V-Drives and Stern DrivesReplies: 1Last Post: 10-09-2008, 07:08 AM -
Hydraulic Line Routing
By Liqui-Fly in forum Technical DiscussionReplies: 4Last Post: 03-15-2002, 08:15 AM
