Results 1 to 15 of 56
Thread: Tygon!
05-25-2019, 08:38 PM #1
Tygon!
Is pissin me the hell off , seems like every time I go out I come in with a leaking bleed line, always at the block ,just at end of nipple. Lines have enuff slack to flow smooth and no sharp turns , I'm goin with merc black chit again. dont look as gud but never ever had all the issues, just cant hold up to the heat I think. Maybe this should b in rant and rave thread but I'm gonna do it hear. Anyone got a good replacement?? O and in top of that I guess I sucked up sum trash on the way in today , has fire on all 6 cranking, damn carbs and lines!!! Just in time for holiday
Wont b down long, will be fixed by 9 in morn and at it again , does merc still sell bleed line? Prob outrageous tho, any substitute?Last edited by Merc 2.5; 05-25-2019 at 08:47 PM.
05-25-2019, 09:28 PM #2
05-25-2019, 09:42 PM #3
Also a few types of Tygon which one are you using?
05-25-2019, 09:54 PM #4
From promarine
05-25-2019, 09:55 PM #5
Softer burn thru easier. My prob now I think but motor runs a gud temp
05-25-2019, 10:33 PM #6
Merc 2.5 thanked for this post
05-26-2019, 11:09 AM #7
What :
NAPA H-1741/8"fiberreinforced fuel injection hose
Why:
Same thing Merc uses , stays in place , pliable , heat and ethanol resistant .
Tygon :
Cuz that yellow **** looks so nice in my fish aquarium ..
05-26-2019, 11:37 AM #8
Stuff is way too pliable. Pro Marine sells the black stuff that works well.
RockTeam Junk
05-26-2019, 03:19 PM #9Supporting Vendor
- 11,838
- 163
- 11
- 795
I’ve used tygon tubing ( fuel and lubricant grade ) I buy from McMaster Carr for 25 years never had any issues with any instillation anywhere on any Mercury V-6 , maybe the product your using has to thin a wall thickness OR it’s not rated for fuel lubrication application ?? I also secure it to every barb with ty straps ...I use at least 1 50’ spool a month
Part # 5552k23 from McMaster - Carr ......404 346 7000 Atlanta , Ga.
BTW Every 2.5 V-6 High Performance Motor ever made that came from racing division came stock with the same yellow tygon I use daily ??
MY BAD I put wrong McMaster part number up the number listed is correct !!!That former number was the bigger tygon I use for water line from poppet to top of block , steel sleeved motors!!!
Jay
Jay @ JSRE
05-26-2019, 03:49 PM #10Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Never had an issue with Tygon and I’ve ran one hot enough to melt the coils to divider plate
Erik Kiser
05-26-2019, 03:53 PM #11
mach351 liked this post
05-26-2019, 04:25 PM #12
05-26-2019, 05:01 PM #13
I used the tygon for bleed line too and would always come back with a oily block from the fittings on the block. I replaced them with the promarine bleed line. So far so good not nearly as oily as it was.
05-26-2019, 08:34 PM #145000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
I use tygon on my 3.0l motors never had a problem and don't even need zip ties. If u buy right size you will tear the hose apart b4 it moves off barbed fitting bleeder if u try pulling hose back off.
I buy mines from eBay but beware of knocks offs
Jay has given you a great place to buy from and if you do your own fabrication work they have everything you can think of
05-26-2019, 08:49 PM #15
I wasn't aware of NAPA store's selling Goldfish ...
So you hang a new build 300x long block together.
Ya gonna use windshield washer fluid "silicon tubing" for your external oil lines ???
How bout your bleed lines .. sneeze one off .. lean city ..
It's 2019 .. the world has changed since 1995 .. just sayin
Now askin, the motors that won Monaco and Indy today. What did they use for upper and lower rod bearings .. ???
https://www.napaonline.com/en/p/NBGH174
Tygon Oil Lines
By bouyhead in forum General Boating DiscussionReplies: 5Last Post: 04-10-2018, 11:21 AM -
Tygon Tubing
By laglass69 in forum Technical DiscussionReplies: 23Last Post: 01-27-2011, 12:01 PM -
Tygon Tubing FYI
By Ranger976 in forum Technical DiscussionReplies: 14Last Post: 05-09-2008, 03:27 PM -
Tygon Tubing
By bucket in forum Technical DiscussionReplies: 12Last Post: 04-08-2003, 11:25 AM
