Results 1 to 15 of 16
Thread: Wire Size Question
05-23-2019, 06:20 PM #15000 RPM
- May 2001
- Maine
- 983
- 35
- 42
- 171
Wire Size Question
I want to run a wash down pump intermittently for a unique application using (2) 12v batteries in parallel for an increased capacity as there will be no charging ability unless done remotely . Where the pump has a 5A fuse, what size wire should I use to connect the batteries together? I was thinking 12 GA would be fine?
05-23-2019, 07:33 PM #2Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
12 ga will easily carry 5 amps
Erik Kiser
05-23-2019, 07:40 PM #3
12 gauge will be fine unless you use a high-amp battery charger on them, in which case you should disconnect them and charge them individually.
05-23-2019, 09:29 PM #4
05-25-2019, 09:01 AM #5
Google "BlueSeas wiring chart" download the PDF, gives you accurate wire sizing info if you know the amp draw, length of the run etc.... use it all the time at work for rigging boats.
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
05-25-2019, 11:14 AM #6
You can also use their circuit wizard... http://circuitwizard.bluesea.com/
05-25-2019, 08:09 PM #7
05-25-2019, 09:05 PM #8
What Capt Morgan is trying to say is it takes some amperage to run a pressure washer
05-26-2019, 10:52 AM #9
Aaargg , back to pre-ssure warshin me deck - ye swabbie ...
all good points ,,, but what do you label that vernacular ? "Necklish"
B-far ye berd'z beak be-comith part ove me nek-lish ...
Well , that or , Use a K+R Pro Cube - SLC to always roll up foot on the floor @ 6.5 MPH . Flick the button, go WOT and on the first pressure washer .002 later. Second washer , .500 into it for 4.500 with two over-rides, one for passin gear the other to wash the bird .. errr .. fish off the deck .. :-)
http://www.krperformance.com/
05-26-2019, 11:35 AM #10
whats up with the tube tv ? AAARRRRRR ?
most overnite successes usually take at least 10 years
Certified turd polisher,
05-26-2019, 11:42 AM #11
05-26-2019, 08:00 PM #12
The TV still works good . Cept for it's in the shop by the milling machine ...
The pirate suit .. I don't think my fat azz could even come close to fitting back in ..
The kid took the center post out of the wood box .. And we put whatever fit .. mama's happy .. so Ssshhhh ..
05-26-2019, 10:49 PM #13
just jiving, love ya brother! my parents just cleared out 2 houses, all of a sudden I have 3 flat screens that I am not sure how to plug in, put 2 analog units by the dumpster, fn things weigh, a ton, and I'm an old school kind of guy, arrghh
05-27-2019, 10:18 AM #14
Notice the lack of concern in my 6 sets of eyes in the picture ... LOL
When hooking up old school TV's be sure to use tinned boat wire and left over tygon from the old days as heat shrink ... :-)
05-27-2019, 10:55 AM #15
More important is how long the run is...but 14g would handle 5A with ease.
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
Need help/advice with new High Amp Alternator wire selection size.
By Mikes402Jetboat in forum Technical DiscussionReplies: 0Last Post: 01-24-2011, 05:14 AM -
Adding an AMP Question on wire
By Liberator*21 in forum Electronics, Audio Systems, and WiringReplies: 3Last Post: 08-14-2009, 01:44 PM -
Mercury Tech: Mercury 40 AMP 4 yellow wire or 2 wire question??
By skeeterboy in forum Technical DiscussionReplies: 9Last Post: 06-13-2009, 10:00 PM -
Plug wire question
By fatjohnson73 in forum Technical DiscussionReplies: 0Last Post: 08-11-2003, 09:47 PM
