Results 31 to 45 of 52
  1. #31
    Apr 2007
    When you pulled the powerhead did you split the exhaust plate? The lower half could still be full of sand. Also you would want to pull the divider plate and check the passages to the block, junk loves to get caught in there.
    I have pulled and split the exhaust plate(Thinking that this is the plates that hold the upper motor mounts too?)
    What is this Divider plate you talk of? is that for the exhaust divider plate that is in between the cylinder heads on the back side if the engine?
  2. #32
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by slpcamaross97 View Post
    Josh Peterson
  3. #33
    Apr 2007
    Thanks for the heads up. Yes i did have that off and cleaned it out. BUT, that was before i found the midplate full of sand and rocks. So im going to pull it tonight and re check all the passages possible.
    Gaskets are cheap at this point. Im about ready to condem the powerhead and try to find another 200hp powerhead.... which does not sound easy.
  4. #34
    Sep 2017
    Ashland city tn
    200 easy come by. When he said split the plates , u should had have to remove the mounts ,and it's a 2 piece plate , u gotta b missin sumthin sumwere, try it with stats completley removed
  5. #35
    Apr 2007
    Took the exhaust cooler assembly apart again last night. Zero debris. Ran wire though each cooling passage that i can see.... all is nice and clear.
    Removed the complete mid section and all the plates.... zero blockage found.
  6. #36
    Chuck of something in somewhere, old pump . Pull the heads yet?
  7. #37
    A few more things. In the lower half of the exhaust plate on the starboard side there is about a 5/16" hole that shoots water into the poppet cavity that isn't readily apparent, double check that it's clear.
    I'm also pretty sure you said you have a 1st design poppet. On a mid 80's 2.4 you would actually have a second design using a round 2 bolt cover. May want to double check you have the right parts in it. You can also verify poppet operation watching the gauge. At about 16-1800 rpm you should see a pronounced drop in pressure when the poppet opens (usually about 10 psi or so).
    I would also swap hoses on the pressure gauges to keep them "honest". Hate to see you knocking yourself out over a gauge gone goofy.
    The only other I'd check right now is with this engine history of sand intrusion, I'd want to look at the water pump base to confirm the bleed hole is the correct size and you don't have something imbedded in it. That can have a fairly dramatic effect on pressure.
    That's about all I can think of at the moment. I'll let you put it all back together then think of something else you should have checked
    Bleed hole!
  9. #39
    Apr 2007
    Yes, Head pulled along with the cyl head water chamber covers externally. Super clean! zero issues
  10. #40
    Dec 2001
    If you run it with out the poppet cover..... and it still has too much psi.....prob in block. And it will water ya garden. From what I read you put a hose on the copper tube..... garden prs... 9 lbs and still had too much when running? head gasket seal.......2.0 gasket .... on a 2.4? seen it.
  11. #41
    Apr 2007
    Bleed hole!
    Where is this bleed hole in the lower water pump base?
  12. #42
    Apr 2007
    I had the poppet valve in place when running it on the garden hose. And yes the garden hose was attached to the copper pipe in the mid section.
    Head gaskets were factory oem never been replaced before. I installed oem gaskets.
    Thanks for the tips though.
  13. #43
    Apr 2007
    Just posting a update.
    At this point, i have taken everything in the mid section apart. I have found two water passage holes blocked with sand. The first one was in the bottom of the mid section- Right by the "exhaust can". My feeling is this is nothing more than a drain and not part of water flow out of the powerhead.
    Second plugged hole was in the lower unit right in the area of the water pump. This hole would drain water into the exhaust area. Also my feeling is that its more for water draining out of the mid section/around the pump.
    Third area i found was more of a possible leak. But in the lower motor mount area, was a hole(from a previous bad motor mount) that was sealed with epoxy. might have been a "ok sealing"... but unsure. I had this damage welded up(water tight).
    The water pump bypass hole in the lower water pump base is clear and open.
  14. #44
    Apr 2007
    Other strange thing that may or may not be a issue was the mid section to mid-plate perimeter gasket was missing/not installed. Along with the exhaust tuner gasket was missing and all 6 bolts were loose(my guess is maybe low torque on the bolts allowed the gasket to be pushed out overtime).
    Im slowly putting it back together now. Unsure of what the results will be. But I've covered everything i can.
    Also putting in new plastic poppet valve waters(Was not replaced on prior repair attempt), and all new poppet valve parts(again).
  15. #45
    Dec 2001
    Ya should be good.... If it can't get out.... it will heat....gasket missing.... well darnnn,,...
  1. Water Pressure to High Need a little help
    By Cervelo777 in forum Technical Discussion
    Last Post: 10-21-2018, 08:54 AM
  2. High Water Pressure After Changng Water Pump
    By maineidyl in forum Technical Discussion
    Last Post: 08-11-2018, 05:10 PM
  3. Mercury Tech: High water pressure & low water temp
    By njj502 in forum Technical Discussion
    Last Post: 10-19-2017, 03:00 PM
  4. Water pressure too high with CLE
    By wired247 in forum Technical Discussion
    Last Post: 06-02-2014, 12:42 PM
  5. Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
    By sasquitch in forum Technical Discussion
    Last Post: 07-31-2010, 09:16 PM
