Results 1 to 14 of 14
    Dec 2006
    Verado supercharger max psi
    Was wondering what is the max psi of charge air can the stock supercharger produce if the bypass valve isn’t a factor. Also does anyone now the difference between the 300 and 350? I know the heads are the same and the block but the cams are different and the computer anything I am missing.
    Dec 2013
    georgia
    I think 350 the charge air is water cooled
    What are you trying to do
    Dec 2006
    Was seeing what all it would take to get a 275 or 300 to the 350-400 numbers. From there try tuning for high boost and race fuel. If the stock charger isn't up to the job of 45 to 50 psi then I'll have to explore another charger systems.
    May 2013
    Connecticut
    I don't think the stock charger is gonna be effective much over 450hp before it becomes a heat pump.
    Look at the Whipple 1.6L 100AX model, rated for 1100cfm and 30 psi. Should be good for 600hp. Put some bigger injectors, fuel pump, head work, bigger cams.
    Rotating assembly is probably fine....could be a beast.
    No reason it can't happen, RB26`s put out 600whp easy =)
    Oct 2009
    Gonzales, La
    45-50 psi???? Isn’t stock like 10?
    Dec 2006
    I think stock is 29psi
    Oct 2009
    Gonzales, La
    Are you talking psia? My 400r runs 16-17 psig stock, which would be about 31 psia. Not sure what the 200-350’s run.
    imo, 16-17 on pump gas without gdi running wot for long periods is plenty high. What fuel are you thinking?
    Dec 2006
    I’m not sure if it is psia or psig. I did a search and the psi I found was 29 psi but could be wrong. I was looking for some of the specs for the Supercharger. Psi, cfm etc. Does mercury make this Supercharger or does someone else make it for them
    Oct 2009
    Gonzales, La
    I believe the verado superchargers are made by ihi. Not sure if the 350/400 are also ihi but they are different.
    Aug 2018
    On a racetrack or at the lake
    Are the pulley sizes the same?
    Quote Originally Posted by engineermike View Post
    Now I'm totally lost ...
    Can we work in common units like Pascals, Torr or inHg ...
    No matter what unit of measure you use, you are in essence measuring all the air the engine doesn't have the ability to convert into work.
    The "cram effect" of more boost will make more power works early in the game. Been there, done that. 540 Big Chevy's with Littlefield retro/ Hi-Helix 8-71 @ 52 psi ran no quicker than it did @ 38 psi. Then with 18* darts it wouldn't even make 30 psi but ran 4 tenths quicker.
    Back to the verado:
    I'm sure a blueprinted case and rotors along with a head that's spent some time on the bench and a pair of mild regrinds along with an adjustable fuel regulator ... will show less "boost" but make more "Brake Horse Power" .
    When the blower doesn't have to work as hard, there is less parasitic drag on the crank, free's up power and is easier on parts .. win-win.
    Them things are quiet as a church mouse. Gotta be a big cork in the intake side. We were working on a stainless header for the exhaust side when Rick George passed away. Pretty small hole in the engine adapter plate if I remember correctly. But room enough to grow. The oil bag is on one side, and plenty of room for a "BOOM" tube on the other ..
  12. #12
    Aug 2018
    Back to the verado:
    He’s just talking lbs/sq in and including atmosphere of 14.7 which I typically don’t see referenced as “boost” is a measurement of restriction as you described.
    If the cams are different as the OP said then the same pulley (compressor speed) and heads will show lower psi as the engine is pumping air more efficiently though can make more power as you mentioned.
  13. #13
    Aug 2018
    According to merc parts catalog the 350 and 400 use the same supercharger/pulley and cams, so then the additional top end power is coming from the extra RPMs spinning the supercharger faster. The 200-300 L6 Verado’s show to all have the same supercharger/pulley and cams, so assume they are just regulating the psi with the bypass valve and controlling airflow with the electronic throttle body.
    From the CARB reports...
    200-216hp@6100/277ftlbs@3250
    225-221hp@6100/277ftlbs@3500
    250-247hp@6100/274ftlbs@4750
    300-291hp@6100/284ftlbs@4500
    350-341hp@5800/320ftlbs@4500
    400-390hp@7000/325ftlbs@4500
  14. #14
    Quote Originally Posted by PRE-Z06 View Post
    Of course you won't look at boost as a restriction in the intake tract until you start slipping ( a mild hint ) serpentine belts . It will become crystal clear when you start shredding 3" Gilmer belts as to what the fix is ..
    This is my last open wheel car ..I sold it to a guy in Alaska of all places ..
    Got boost .. err .. total matched airflow
  15. Likes PRE-Z06 liked this post
  1. Supercharger for mercury verado
    By LAGUNA TOPCAT in forum Misc. Parts and Accessories
    Last Post: 02-26-2019, 10:56 PM
  2. Weiand Supercharger
    By advjet in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-04-2008, 12:02 PM
  3. BWM Supercharger
    By JohnBoy in forum The Scream And Fly Lounge
    Last Post: 10-13-2007, 03:35 PM
  4. Supercharger on an F-150. Anybody done it?
    By Boz in forum The Scream And Fly Lounge
    Last Post: 09-09-2007, 10:07 PM
