Results 1 to 9 of 9
    Jun 2014
    Is this flywheel bad?
    My gut tells me it is but I wanted to ask the pros. Not sure if you can tell by the pics but the splines on the inside of the flywheel are pretty much gone. They only come up about 1/32 of an inch before it turns smooth.
    I couldn't find a key way other than the splines in the flywheel. Should there have been a separate key way?
    Could this be causing my missfire issue?
    Attached Thumbnails Attached Thumbnails 20190522_100600.jpg   20190522_100553.jpg   20190522_100618.jpg
  2. Thanks SS Minnow thanked for this post
    Likes Glasstream15 liked this post
    Jun 2009
    central minnesota
    f/wheel looks junk imo
  4. Likes tux974 liked this post
  5. #3
    Dec 2001
    Wow never seen one like that. I have flywheels if ya need one.....$40 you pay shipping.....But ya may find one local in Fl..... for free. Most like the 16 amps.... and don't use the big black 40s.....
    Surprised it runs at all. Fly whl is toast. Crank may be comped too. Splines look twisted.
  7. Likes rock, tux974 liked this post
    Pekin, IL
    Check crank end closely. No point in ruining another flywheel.
    Rock
    Team Junk
  9. Likes keefallan, tux974 liked this post
  10. #6
    Jun 2014
    Thanks for the responses. I will check crank splines real good. Maybe it's time to upgrade to an EFI motor. This has been a good engine but it's getting tired.
  11. #7
    Apr 2011
    Western NC
    Crank spline looks like it may be OK.
  12. #8
    Like mentioned above, flywheel is done.
    Thats a 40amp cast iron flywheel.
    The key is not a separate piece. Key way is 2 splines together on the flywheel.
    Make sure your tighten the flywheel properly when installing new one.
    Have seen that happen when flywheel was run loose.
  13. #9
    Jun 2014
    Thanks for all the help. I changed the flywheel out with a used one from a salvage yard. Runs like a sewing machine now. Just in time for summer!
  1. Flywheel ?
    By dezracer in forum Technical Discussion
    Last Post: 02-10-2012, 11:49 AM
  2. 35 xs flywheel
    By Hebert519 in forum Outboard and Racing History
    Last Post: 06-20-2003, 05:15 PM
