Results 1 to 4 of 4
Thread: Engine flushing question
05-21-2019, 05:46 PM #1Member
- Jun 2014
- FL
- 32
Is it ok to run the engine using the hose flush connection that goes through the back of the engine cowling or should it only be ran on muffs when flushing.
FWIW it's a 99 merc 2.5l 200hp
05-21-2019, 07:58 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
I don’t know how water pump would get water for lube and keep from blistering but they add those flush inlets for a reason check with your OEM dealer for straight answer ..
JayJay @ JSRE
05-21-2019, 08:38 PM #3
Those flush attachments are designed to be flushed with the engine off. You cxan run it on the muffs if you want
05-21-2019, 08:40 PM #4Member
- Jun 2014
- FL
- 32
Thanks flabum. Guess I will pick up some muffs
By Whaaaaat in forum Technical DiscussionReplies: 0Last Post: 08-15-2017, 06:33 PM -
Question about flushing after saltwater use....
By Steve2ManyBoats in forum Technical DiscussionReplies: 2Last Post: 07-30-2013, 03:39 PM -
Engine Flushing
By skatermike24 in forum Technical DiscussionReplies: 2Last Post: 11-18-2007, 08:03 AM -
Engine Flushing Question
By skatermike24 in forum Technical DiscussionReplies: 1Last Post: 10-11-2007, 07:17 PM -
Question about flushing the motor
By MattT1685 in forum General Boating DiscussionReplies: 1Last Post: 07-16-2006, 02:14 PM
