Results 1 to 4 of 4
    Jun 2014
    Question Engine flushing question
    Is it ok to run the engine using the hose flush connection that goes through the back of the engine cowling or should it only be ran on muffs when flushing.
    FWIW it's a 99 merc 2.5l 200hp
    I don’t know how water pump would get water for lube and keep from blistering but they add those flush inlets for a reason check with your OEM dealer for straight answer ..
    Jay
    Jay @ JSRE
    Ft. Lauderdale, Fl
    Those flush attachments are designed to be flushed with the engine off. You cxan run it on the muffs if you want
    Jun 2014
    Thanks flabum. Guess I will pick up some muffs
  1. Engine flushing question
    By Whaaaaat in forum Technical Discussion
    Last Post: 08-15-2017, 06:33 PM
  2. Question about flushing after saltwater use....
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 07-30-2013, 03:39 PM
  3. Engine Flushing
    By skatermike24 in forum Technical Discussion
    Last Post: 11-18-2007, 08:03 AM
  4. Engine Flushing Question
    Last Post: 10-11-2007, 07:17 PM
  5. Question about flushing the motor
    By MattT1685 in forum General Boating Discussion
    Last Post: 07-16-2006, 02:14 PM
