Results 1 to 6 of 6
    Jan 2015
    VRO replacement with traditional fuel pump, which one?
    Pretty much like the title says. Search function on here did not work for me, so I will ask.
    I have a 1990 2.0L v4 140 Evinrude. Some claim a single fuel pump is fine, I have seen some claim I need to put two together like on the v6. Which one do I need, anybody here know?
    Thanks!!
    Jan 2008
    SUMMERVILLE S.C.
    i've put one old style on bunches of v4 loops with no problems...438559 i think is the # for the pump with a pulse fitting...screw it to the old vro bracket ...hook the gas lines up in and out...you can hook the old pulse fitting to the new pump pulse and good to go...
  3. Likes SS Minnow liked this post
    Ft. Lauderdale, Fl
    BRP also sells a pump that looks like a VRO, but does not have the oil side..... a little pricey though
  5. Likes SS Minnow liked this post
    Oct 2005
    Oklahoma
    I've used a Mercury pulse pump that has only hose fittings. Works great.
    Jay @ Holeshot Marine
    OKC, OK
    405-672-5700
  7. Likes SS Minnow liked this post
    Gothenburg, Sweden
    Why not use an electric pump? Carter is very good.
  9. Likes SS Minnow liked this post
  10. #6
    Jan 2015
    Quote Originally Posted by flabum1017 View Post
    Yeah, I just wanted the old style OMC that I can rebuild for $20. Thanks though!!
    Quote Originally Posted by OkieBoatMech View Post
    Like above, just want an OMC, thanks though!!
    Quote Originally Posted by Markus View Post
    Do not need to complicate what I have. A simple fuel pump will work for what I have. Thanks though!!
    Quote Originally Posted by BOATMANBLUES View Post
    That was the part number I had, just wanted to see if someone had run one and if it worked. Thanks!!!!
  11. Likes keefallan liked this post
  1. 66K-13907-00-00 EFI replacement fuel pump with filter for Yamaha
    By Speed & Custom Marine in forum Misc. Parts and Accessories
    Last Post: 04-21-2017, 01:03 PM
  2. Replies: 1
    Last Post: 10-04-2016, 10:20 PM
  3. Mercury Tech: Replacement High pressure fuel pump for 2.5/280?
    By fastkat101 in forum Technical Discussion
    Last Post: 08-21-2014, 04:47 PM
  4. Mercury XRi fuel pump replacement question
    By H2Okie in forum Technical Discussion
    Last Post: 04-05-2014, 12:01 PM
  5. replacement fuel pump??
    By boatn70 in forum Technical Discussion
    Last Post: 08-01-2001, 11:21 PM
