Results 1 to 5 of 5
Thread: SeaStar Hydraulic steering issue
05-21-2019, 11:08 AM #1Member
- Aug 2014
- Orillia, Ontario
- 36
Hey,
I have a Seastar Hydraulic system on the boat I bought recently. I ran it this weekend for first time and noticing an issue with the system. This is the first rig I have had with hydraulic, so am new to the systems.
I find the steering wheel continuously losing centre, and when running the boat the wheel is constantly needing to be rotated in order to keep the boat straight..Some times a whole wheel rotation is done by the end of the journey.
ALSO, at high speeds the motor seems turned more then normal...yet the boat is going straight...dont know if this is just torque steer or if the cylinder has an issue and isn't holding motor properly.
Is this normal for hydraulic systems? Whats the best way to diagnose between helm and cylinder as the issue, and are their seal kits or rebuilds available on these?
Thanks in advance.Last edited by vonner25; 05-21-2019 at 11:40 AM.
05-21-2019, 11:31 AM #2
This is normal to a point. How far is the run you take? If your going 10 miles I would think the wheel will continue to turn to keep you straight, maybe even a full revolution. (I tried to use a cord to trim on the wheel, constantly going around the helm till it broke!). The steering wheel will never stay centered.
1973 Viper - sold
1978 Viking - sold
1995 XB02
05-21-2019, 11:35 AM #3Member
- Aug 2014
- Orillia, Ontario
- 36
Yes id say 5-10 mile run at differing speeds
05-21-2019, 12:32 PM #45000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
first thing is to go through the purge procedure and make sure no air is in the system anywhere...if it is air free and continues this , then it is almost always the shuttle valve in the bottom of the helm sticking...take it apart, clean it up till it moves freely , and put it back together...
vonner25 thanked for this post
05-21-2019, 06:51 PM #5
Seastar will never keep the steering wheel centered; it's in the valving... there will always be a little helm movement before the motor starts to move. If you are running high (surfacing prop) not much you can do to reduce it. If running normal (steering tab under the anti-ventelation pltae is in the water) then you can adjust the steering tab to reduce steering torque. If it's harder to steer left, adjust it right...
Hydraulic Steering Issue
By KnotNow in forum Props, Setup, and RiggingReplies: 0Last Post: 08-09-2018, 12:56 PM -
Seastar Pro hydraulic steering
By dlivewyer in forum Misc. Parts and AccessoriesReplies: 0Last Post: 06-15-2014, 04:01 PM -
Steering Hydraulic Issue.. Help!!
By liquidforce13 in forum Technical DiscussionReplies: 4Last Post: 12-15-2010, 12:58 PM -
By mbrien in forum Props, Setup, and RiggingReplies: 12Last Post: 02-20-2008, 06:22 PM -
Seastar hydraulic steering
By BillB in forum Technical DiscussionReplies: 14Last Post: 04-05-2002, 10:47 PM
