Results 16 to 22 of 22
05-21-2019, 07:05 PM #16Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-21-2019, 09:48 PM #17Member
- Apr 2009
- oregon
- 37
05-22-2019, 02:14 PM #18Member
- Apr 2016
- Frederick, Maryland
- 34
Biggest issue is the random times it falls on it's face. It acts like it is going into slow mode but all I need to do is throttle back to neutral and throttle back up I can do it and never come off step. That's how fast it makes a difference timing is dead on 4deg atdc idle and 18deg btdc at wot verified at 5000rpm. One day it was double firing on the #4 cylinder swapped power packs double fire gone rest of the issues stayed at times It sounds like it's missing but have good spark at idle and has spark on the timing light at 3000 or so rpm it's tough to test it above that with the jet unit because it sucks all the water out of under the boat when trying to do it on the trailer and cavitates to 6000rpm and above 3500rpm it's running 30mph. I'm thinking it's the stator but don't want to throw $300 at it if that isn't the problem
05-22-2019, 02:16 PM #19Member
- Apr 2016
- 34
05-22-2019, 08:52 PM #206000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Stop sight for backwards voltage flow.
Prevents it swaping polarity.
06-11-2019, 09:08 AM #21Member
- Apr 2016
- 34
UPDATE
Finally was able to get the flywheel off. It had surface rust between the crank and flywheel took more pressure than any flywheel i ever pulled. Thought it was going to break my puller before it let go. So anyway found the stator to be leaking and sure enough failed resistance tests on both charge coils also tested the trigger. I found 2 issues with that so ordered a new stator and trigger will have it back together tomorrow and test run it on the water on Friday. Pretty sure those were my issues with it going to slow mode at random times and sometimes feeling like a slight misfire. Now I hope it also takes care of the midrange roughness. If not I believe that will be an easy fix. What I have read those carbs had issues with the side plates leaking.
06-11-2019, 09:33 AM #22Member
- Apr 2016
- 34
I know what a diode does. I was asking what the purpose of it being in that harness was. But no worries I got that figured out and yes it can be eliminated it has no effect on the ignition system once removed. It is only there for protection of the ignition system incase of a back feed through the shift interrupt harness. Since I'm running a jet unit and have no use for the shift interrupt. I can remove it and simply connect the black and yellow wires together. Now if I was running a prop unit I could not eliminate it from the system because it is needed to be able to shift the motor without issue. And yes it would be a bad idea to remove the diode from the system because it would allow back feed from the ground side of the harness to destroy the ignition components.
OMC Tech: 97 225 johnson, many many issues
By rama in forum Technical DiscussionReplies: 16Last Post: 08-01-2011, 05:42 PM -
OMC Tech: 1990 johnson 225 powerhead to a 1994 johnson 150 midsection??
By 85HYDROSTREAMVECTOR in forum Technical DiscussionReplies: 1Last Post: 03-02-2011, 08:20 AM -
1990 Johnson 90 HP VRO
By lakesmodified in forum Technical DiscussionReplies: 12Last Post: 06-28-2007, 10:47 AM -
235 Johnson issues
By PHISH in forum Technical DiscussionReplies: 12Last Post: 06-06-2006, 08:03 PM
