Results 1 to 8 of 8
    May 2018
    Norway
    Safe engine height without nosecone or water pickup
    I have a 21 foot v-hull that i am rigging for the first time. Then engine has a standard water intake, how much of the water intake should stay under the hull to ensure sufficient water for cooling?
    The hull has a 24 degree V, lift has 6" setback.
    Pekin, IL
    Most guys take them to the lake and run em. Keep raising motor till water pressure drops and that is your limit. You will likely be able to run with top hole well above bottom of boat. As water clears pad it goes pretty much as straight up as it can, dependent on speed of course, and with set back it will reach up there pretty high. Good luck.
    Rock
    Team Junk
  3. Likes tux974 liked this post
    May 2008
    redondo beach
    On my current setup I run a standard lower with water catch plates on each side of the water intakes with the top two holes plugged. I can start to surface the prop and still maintain water pressure. Might want to look into something like that.
    you gotta start with a water pressure gauge.
  6. Likes tux974, Rigaud, challenger 77, 1954bmw liked this post
    Jul 2011
    Gloucester, VA
    When the alarm goes off it's to high
    1-Water pressure
    2-Temp
    3-Handling
    These would be my suggestion to work with.
    Keep in mind all above could/will change or have an affect with LU used.
    I’ve run 2” above without a cone. Cone doesn’t matter if it’s not in the water
    Feb 2011
    HUDSON, FLORIDA
    WE ran stock 15 ''in lines on 20 '' transoms, all the the time. no set back never had cooling trouble. mercs only, no omc. if u looked at it yould say no way but ran em wide open. flat on transom, stock lower.
  1. Mud or sand in low water pickup nosecone
    By The Bilge Idiot in forum Technical Discussion
    Last Post: 09-04-2006, 01:54 PM
  2. engine height and water pressure
    By bdawg13919 in forum Technical Discussion
    Last Post: 08-02-2006, 08:51 PM
  3. Aftermarket low water pickup nosecone help
    By Mr Walker in forum Technical Discussion
    Last Post: 06-30-2006, 09:03 AM
  4. Aftermarket low water pickup nosecone help
    By australian ski racer in forum Technical Discussion
    Last Post: 06-20-2006, 06:55 AM
