Results 1 to 5 of 5
Thread: 1998 pro max 300 - oil leak?
05-20-2019, 01:50 PM #15000 RPM
- Jan 2006
- 132
1998 ProMax 300 - went out in the barn the other day and noticed a very small amount of oil on the top of the lower unit. It appears that is seeped out between where the lower and mid section come together. I have checked everywhere and cannot find oil leaking. Any ideas on something to check that I might have missed. The engine runs fine, but if there is an oil leak somewhere I would prefer to catch it sooner than later.
Thanks
05-21-2019, 07:50 AM #2
If it is toward the front of the lower you may have a leaking shift shaft seal. Check lube for water intrusion. Was leaking substance clear oil or was it black?
RockTeam Junk
05-21-2019, 07:58 AM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Unfortunately operating as intended providing its not what rock said.
Is it dripping from the exhaust vents on the bottom of the mid.
05-28-2019, 12:34 PM #45000 RPM
- Jan 2006
- 132
It is towards the back and appears that it could be coming from the exhaust vents.
05-28-2019, 09:04 PM #55000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
not sure if all 3.0s are the same but my 200 optimax had the same thing goin on and it wasnt gear lube it was the crank seal on the motor seaping and draining out between the mid and gear case.
1998 Johnson 200 Vacuum Switch Leak
By sailnaked6842 in forum Technical DiscussionReplies: 4Last Post: 02-16-2015, 11:22 AM -
OMC GEARCASE Q: WILL A 1998 60DEGREE V4 LOWER FIT a 1998 90DEGREE V4 Motor?
By joe-doggs in forum Technical DiscussionReplies: 7Last Post: 09-13-2003, 06:56 PM -
Leak down ?
By vectorizer in forum Technical DiscussionReplies: 8Last Post: 08-01-2003, 12:21 AM -
1998 Hydrostream Valero YT, 1998 Pro Max 225
By at100plus in forum Props, Setup, and RiggingReplies: 4Last Post: 04-22-2001, 09:29 PM
