Results 1 to 1 of 1
Thread: Troubleshooting a 1999 Merc 200
05-20-2019, 12:29 PM #1Member
- Jun 2014
- FL
- 32
I have a rough idle and cough through exhaust problem that I am trouble shooting. (This problem actually started a few years ago but I had to park the boat because of life issues)
Good compression on all 6 cyl. good gas and clean carbs.
DVA check of all 6 coils yielded only about 30 vdc on all 6 coils using starter. Further tests showed only 118 vdc on blk/ylw switch box leads using starter motor rpm.
Stator low speed tests came back good.
Stator high speed tests came back below limit at 18 ohms. Again only using the 400 rpm chart
ohm'd stator and it was 1,000 ohms lower than limit. Would you consider this a bad stator. 2445 ohms was my reading.
My other concern is that the white wire from the trigger got pinched pretty bad between the switch boxes. Probably from the last time I had them off. Could this cause an issue? The insulation isn't torn but it got smashed down pretty good....
motor runs good above idle.
1999 Mercury 200 carb engine OG841934
2003 Merc EXLPTO 90 warning horn: troubleshooting a non-existent problem?
By gw204 in forum Technical DiscussionReplies: 3Last Post: 06-15-2016, 11:35 AM -
Merc 1500 Inline Troubleshooting Help Please
By cbattles in forum Technical DiscussionReplies: 18Last Post: 08-12-2009, 01:34 PM -
Merc. 200 hp. EFIyr.2000 troubleshooting stator
By Dataphat in forum Technical DiscussionReplies: 0Last Post: 05-10-2006, 07:27 AM -
Merc Stator Troubleshooting question
By Tom Smyth in forum Technical DiscussionReplies: 0Last Post: 05-08-2005, 09:37 AM
