Results 1 to 4 of 4
Thread: Reed valves
    May 2019
    Anderson sc
    Reed valves
    Reman power head replacement 1999 Mercury 200 efi what is the best way to clean reed valves? Had #6 cylinder melted down and shavings are in reed's. I know what caused the melt down going back together. Thanks
    Feb 2014
    Missouri
    If just dusting some air and brushing when apart/ disassembled apart. (Just blowing compressed in can bend it) most can also be cleaned with gas (not sure about opti)
    Melted in metal means fresh reeds.
    Sanding and such alters the performance and best handled buy a competent reed tuner.
    Disassembled clean with carb cleaner after blow with compressed air , I use TDR reed valves in ALL my engine rebuilds , call for prices .
    832 597 2603
    Jay @ JSRE
    Jay @ JSRE
    Oct 2017
    Hugo, MN
    Man, if I had the motor tore down that far and ANY question about the reed condition, I'd replace them.
    Just my opinion.
  5. Likes sonicss33 liked this post
  1. OMC Tech: What reed valves to use?
    By 5.0fred in forum Technical Discussion
    Last Post: 05-24-2009, 05:39 PM
  2. OMC Reed valves
    By 76Stingray in forum Technical Discussion
    Last Post: 03-09-2009, 08:29 AM
  3. Reed Valves
    By the rev in forum Technical Discussion
    Last Post: 06-04-2007, 04:55 PM
  4. Reed Valves
    By Mr.Rude in forum Technical Discussion
    Last Post: 05-21-2006, 09:22 PM
  5. reed valves
    By ptextreme in forum Technical Discussion
    Last Post: 03-27-2006, 10:10 PM
