Results 1 to 11 of 11
Thread: Transom and jackplate bolts.
05-18-2019, 07:22 PM #15000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
I replaced my transom to jackplate and jackplate to motor bolts last year with F593C-THE bolts.
The boat gets low hour use, freshwater, never jumping wakes (intentionally) and if the water is rough I don't go out... Hydrostream Viking.
Did I use the wrong bolts? If so, how bad?
Thanks
Christopher Johnson
rochelle howell thanked for this post
05-19-2019, 05:48 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
What is f593c bolt?
Tap bolts are similar to hex bolts except they are fully threaded no matter what their length. They are designed to be used in drilled and tapped holes. They are used in applications where a stud with a nut on each end would be impractical. Used in low strength applications. Stainless Steel material.
Not much info I can find. Full thread? Designed to be used in threaded holes? Not liking the used in low strength apps......I would get some fasteners from a source that can tell you what the fasteners are actually rated for. As always, jm2cts...
05-19-2019, 07:36 AM #35000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
It's a technical specification for a higher strength stainless steel bolt as far as I can find:
https://www.portlandbolt.com/technic...ons/astm-f593/
05-19-2019, 07:43 AM #45000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
Also, just noticed the heavy-duty bolts that hold my jackplate together (from the factory) are labeled F593C.
05-19-2019, 07:45 AM #55000 RPM
- Western, Pennsylvania
- 163
I went with ARP bolts, they were expensive, but I'm not worried about any bolt failures now.
Captaincj thanked for this post
05-19-2019, 08:10 AM #6
F593 is an ASTM standard. The bolts with that marking meet the standard, whereas a generic 304/316 stainless bolt may not. They are the same or similar to what the outboard manufacturers put in the crate with the motor, and are plenty adequate.
Ron V
05-19-2019, 08:16 AM #75000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
Thanks Ron, I did feel better after seeing my jackplate assembled with the same bolts.
05-19-2019, 10:51 AM #8Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I just googled them and that is what they came up with. The consensus is use them.....
05-19-2019, 10:58 AM #95000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
Thanks gentlemen.
05-19-2019, 11:48 AM #107000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
05-19-2019, 12:36 PM #115000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
Transom/jackplate bolts?
By pyro in forum General Boating DiscussionReplies: 23Last Post: 07-06-2015, 11:15 PM -
Transom bolts bending. CMC jackplate laying over!
By Revolution141 in forum General Boating DiscussionReplies: 20Last Post: 08-03-2011, 06:31 PM -
Best jackplate & transom bolts
By David Borg in forum Technical DiscussionReplies: 8Last Post: 05-07-2008, 04:32 AM -
Transom Bolts
By gstorr in forum Technical DiscussionReplies: 12Last Post: 10-06-2007, 07:39 PM -
Again with the transom bolts!?
By Techno in forum Technical DiscussionReplies: 12Last Post: 11-22-2001, 10:47 PM
