Results 1 to 3 of 3
    Chesterfield, MI
    1992 150 XRI voltage regulator questions
    OK so I need one regulator. First question, any of the cheap regulators seem to work fine? Mercury/Quicksilver IMO is outrageous for pricing. Anyone have any good luck with the cheap 20-40 dollar ones? IMO, the biggest reason any of them go bad is because of weak batteries or trying to charge a deep cycle. Provided I use a good known starting battery and stator is working properly and cables/connections good as simple as these rectifiers/regulators are wouldn't a cheaper one work as good as Mercury/Quicksilver? Looking at something like this >>> https://www.ebay.com/itm/5-Wires-Vol...YAAOSwPrlbf2OA
    Second question, I see the newer style regulators have a 30 amp fuse on one red wire. IS it possible to put an inline fuse on a older style regulator thus preventing a fire/melting of a regulator and wiring if one or both go bad? Seems like cheap insurance to keep damage to a minimum. Figured someone on here must have seen this as well and maybe tried doing this?
    Sep 2017
    Ashland city tn
    On fuse. That's sounds like a good idea to me , sure would b lot less fires u would think , on regulator anything worth a try once but check on cdi , or from pro marine
    TN
    poor connections is what destroys regulators.
    don't use the push in bullet connectors.
    use a molex crimp connector or solder.
    be sure battery cables are clean and tight on both ends.
    i haven't tried the cheap regulators but i would if i needed one.
  1. possible to add voltage regulator?
    By wolfgangb in forum Technical Discussion
    Last Post: 03-26-2015, 04:37 AM
  2. 275 Merc Voltage Regulator Questions
    By RaceCarRobbie in forum Technical Discussion
    Last Post: 05-13-2010, 01:45 PM
  3. Voltage regulator
    By CNT in forum Technical Discussion
    Last Post: 07-05-2005, 10:07 AM
  4. Voltage regulator
    Last Post: 06-09-2004, 05:19 PM
  5. Voltage Regulator
    By jamoore in forum Technical Discussion
    Last Post: 07-18-2001, 11:54 AM
