Results 1 to 5 of 5
    Mar 2018
    NJ
    2000 Mercury 200 efi
    Today's Tech question--Can you swap out 1997 200 efi gasket heads to a 2000 200 efi O-ring motor. If so what CC should you stay at. Thank you
    May 2014
    Livingston, Louisiana
    O-ring blocks have taller decks to achieve correct squish clearance being the head is sitting directly on block (piston not coming all the flush to top). The use of a gasket will give you excessive squish clearance. Some machining can be done to make it possible, but not a direct bolt on.
    Sep 2017
    Ashland city tn
    Forbes is dead on , the mach shop guy that's knows what he doin can cut block for gaskets but other than that u cant run em
    Mar 2018
    NJ
    How does the 200 efi o-ring motor compare to a FF 200 efi. Power-reliability-fuel.
    May 2014
    Havnt personally tested them side by side in real world conditions apples to apples, but the O-ring 200 is a strong runner, The cdm ignition softens it up some down low compared to the switchbox set up, by delaying timing advance, that makes it feel like it’s weaker but it’ll run with best of them once you going. Put switchboxes on it and you’ll be surprised at the improvement in holeshot
  1. 2000 mercury 225 efi
    By bill6ft6 in forum General Boating Discussion
    Last Post: 05-13-2019, 01:38 PM
  2. 2000 Mercury 280
    By wterry50 in forum Outboard Engines
    Last Post: 11-26-2018, 05:11 PM
  3. 2000 Mercury 225 PRO MAX
    By Msharp477 in forum Outboard Engines
    Last Post: 07-25-2018, 09:37 AM
  4. Mercury Tech: Mercury 2000 200 EFI
    By Tomaranger in forum Technical Discussion
    Last Post: 08-17-2015, 09:27 PM
