Results 1 to 6 of 6
05-16-2019, 06:55 PM #15000 RPM
- Mar 2018
- North west Missouri
- 143
- 7
Driving fast with single cable steering
My trolling motor cable broke so Im going to the lake tomorrow with it removed, no batteries, and no gear. It's a 17 ft boat that does 59 GPS loaded. It has normal single cable sterring.
Anybody been able to drive a boat fast with that kind of system? I'm expecting mid 60s with 200 plus pounds removed. 50 of that off the bow. Another 50 from the front compartments.
05-16-2019, 07:14 PM #2Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1267
- 368
I wouldn't the steering torque will be stronger at 60 I know people do it but that is putting alot of pressure on one cable and they are rated for 50.
05-16-2019, 07:53 PM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
do it if you must...with a functional kill switch. test to make sure the kill switch definitely works.
05-17-2019, 03:51 PM #4
So I was runnin a 15ft bass boat with a 200 for its last motor , I went thru 9 motors in 10+ yrs all with a single cable, stupid and dumb but I never killed myself , boat wouldnt run over 65 with any motor because of handling issues , thing is the torque on the wheel leaves no room for balance correction, just test ur kill switch and make sure u got red loctite on the single bolt holding it to motor , but I did drive mine many many yrs like this , started with a 70 merc up to a 200 , both brands ,rudes and merc
05-17-2019, 07:36 PM #5
I had a 16' Checkmate when I was in highschool with a 150 on the back. When I was ignorant and didn't even know hydraulic steering existed. I had no idea what RPM, prop, or speeds I was running, but it SUCKED holding that wheel to the right. Luckily I was 18 and in good shape. Also ignorantly dumb. I wouldn't do it again, nor recommend it.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
05-18-2019, 12:18 AM #6
No I dont recommend it either but in sum people cases ,u can do it if u just wanna get in water. But dont b tryin set too speed records with 1 cable. It's just to hard to handle and dangerous, but wont stop you from getting on water
Single cable steering problem
By playsk8r in forum Technical DiscussionReplies: 7Last Post: 07-16-2012, 10:44 AM -
Single Cable Steering / 150 hp Pro V
By roosta~tail in forum General Boating DiscussionReplies: 2Last Post: 05-12-2011, 03:05 PM -
Single Cable Steering ?
By JLHTEC in forum Props, Setup, and RiggingReplies: 10Last Post: 03-19-2009, 07:42 PM
