Results 1 to 7 of 7
Thread: 1998 300 pro max hard starting
05-16-2019, 03:55 PM #1
i have a 300 pro max cranks, starts, runs 2-3 seconds then stalls. restart runs 2-3 seconds then stalls. i have to do this 5-10 times before it will stay running. any idea where to start? thanks for the post snf.
05-17-2019, 03:19 PM #2
When it does start hiw does it run. on all 6?, sounds almost like u tryin start it on 3 cyl
05-17-2019, 04:05 PM #3
05-17-2019, 04:12 PM #4
Is water blackish when it starts or idling? Flooding itself?
05-17-2019, 04:16 PM #5
No not at all. As far as I can tell.
05-18-2019, 12:20 AM #6
I not a Efi kinda guy so maybe sumone will chime in , but another thing comes to mind is the tps? Has it been checked
05-18-2019, 02:02 AM #76000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Pretty much like a carb just different controls for same thing.
Fuel comes to mind first. Then the electronics controls for its version of choke.
If yours still runs the stator and stuff it might be weak. Considering it eventually runs fine though if something was off it would be tougher to find.
The bit sluggish would probably point to fuel again.
Tps has a rep for a lot of faults and easy to check and next on the list. Also easy to check first.
Mercury Tech: 260 hard starting
By jas638 in forum Technical DiscussionReplies: 3Last Post: 06-20-2010, 09:22 PM -
Mercury Tech: 260 OS hard starting
By jdinny in forum Technical DiscussionReplies: 6Last Post: 06-08-2010, 10:30 AM -
Hard starting
By whipper in forum Technical DiscussionReplies: 3Last Post: 07-15-2009, 11:17 PM -
Hard starting help
By Jbarn1951 in forum Jet Boats, V-Drives and Stern DrivesReplies: 2Last Post: 10-09-2008, 06:04 PM -
Hard starting V8
By Rhummer in forum Technical DiscussionReplies: 3Last Post: 08-19-2003, 10:37 PM
