Results 1 to 7 of 7
    Oct 2006
    1998 300 pro max hard starting
    i have a 300 pro max cranks, starts, runs 2-3 seconds then stalls. restart runs 2-3 seconds then stalls. i have to do this 5-10 times before it will stay running. any idea where to start? thanks for the post snf.
    Sep 2017
    Ashland city tn
    When it does start hiw does it run. on all 6?, sounds almost like u tryin start it on 3 cyl
    Oct 2006
    Quote Originally Posted by Merc 2.5 View Post
    No I'm pretty sure it's running on all 6 cylinders once it starts and warms up seems to run fine but maybe a little bit on the sluggish side otherwise all sounds good
    Sep 2017
    Ashland city tn
    Is water blackish when it starts or idling? Flooding itself?
    Oct 2006
    No not at all. As far as I can tell.
    Sep 2017
    Ashland city tn
    I not a Efi kinda guy so maybe sumone will chime in , but another thing comes to mind is the tps? Has it been checked
    Feb 2014
    Missouri
    Pretty much like a carb just different controls for same thing.
    Fuel comes to mind first. Then the electronics controls for its version of choke.
    If yours still runs the stator and stuff it might be weak. Considering it eventually runs fine though if something was off it would be tougher to find.
    The bit sluggish would probably point to fuel again.
    Tps has a rep for a lot of faults and easy to check and next on the list. Also easy to check first.
  1. Mercury Tech: 260 hard starting
    By jas638 in forum Technical Discussion
    Last Post: 06-20-2010, 09:22 PM
  2. Mercury Tech: 260 OS hard starting
    By jdinny in forum Technical Discussion
    Last Post: 06-08-2010, 10:30 AM
  3. Hard starting
    By whipper in forum Technical Discussion
    Last Post: 07-15-2009, 11:17 PM
  4. Hard starting help
    By Jbarn1951 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 10-09-2008, 06:04 PM
  5. Hard starting V8
    By Rhummer in forum Technical Discussion
    Last Post: 08-19-2003, 10:37 PM
