Results 1 to 3 of 3
Thread: Modvp22 , Mirage setback
05-15-2019, 08:39 PM #1
What setback did you say you run on your River Racer ? Even with a cleaver with a 10" plate and 15" os mid it seems to fly even at neutral trim and even tucked a bit. Thanks Mike
Cheaters never Win !!!
05-16-2019, 05:42 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
Your 15” setback ( if stock OEM) already has a 2” off set built in and with your 10” jack-plate is putting you back at 12” total . I was sponsored by Mirage winning World and High Point Champion multiple times I used 9 1/2” rapid Jack with 20” mid that had no offset so I was only truly 9 1/2” off the transom , my boats sweet spot was at 7/8” inch above split case if that helps , IMO and I dont know your Hull weight or set up but you may be a bit far back causing your rig to be a bit front end kitey ...
Pretty boat ,
JayJay @ JSRE
05-17-2019, 07:05 AM #3
Thanks Jay. I can get it down to 1237 with me at 200lbs ,Brailles , 15" untouched os mid and Sportmaster. Never had a chance to weigh just the hull. A bit too much setback is what I'm thinking too. Currently I'm only running 7 petal 200 so it's not the horsepower that's causing the issue.
Thanks for the input. MikeCheaters never Win !!!
How much setback for a Mirage Jaguar ModVP
By JDI, Inc. in forum Props, Setup, and RiggingReplies: 0Last Post: 10-31-2011, 03:49 PM -
Thanks to Instigator & ModVP22.............
By Raceman in forum The Scream And Fly LoungeReplies: 18Last Post: 10-15-2005, 09:08 AM -
Setback On A Mirage R.r.
By twister in forum Props, Setup, and RiggingReplies: 22Last Post: 04-19-2004, 02:17 PM -
ATT. ModVP22
By Jeff "Yammer" in forum General Boating DiscussionReplies: 1Last Post: 07-01-2003, 06:17 PM -
MODVP22 venting...winter is here
By MODVP22 in forum General Boating DiscussionReplies: 23Last Post: 11-28-2002, 08:42 PM
