Results 1 to 9 of 9
    Jun 2004
    long island
    Looking for Evinrude mechanic - western Suffolk NY
ID:	438892Click image for larger version.
ID:	438893Click image for larger version.
ID:	438894Click image for larger version.
    Im looking for an Evinrude mechanic to work on my engine
    i have a what I think is a V4 140 on a newer midsection
    PO said power head was modified
    Dont know too much about it
    Also have a 2 cylinder 70 Tohatsu needing attention.
    Any leads appreciated
    Photos on request
    Thanks!
    Sep 2011
    maryland
    Are you able or willing to do any work yourself? People can talk you thru some of the basic things on here. A shop manual goes along way. But if not, I understand too. I just don't know anyone in that area.....sorry
    Btw, I love the v6 xp150 cowl on a v4...........great stuff.
    Jun 2004
    long island
    Thanks!
    i have limited time and would rather have a pro work on it.
    i have my own skill sets but working on old outboards is not one of them
    Yeah, the cowl turns a lot of heads especially since it’s on a 13’ Bullet!
    thanks again !
    Feb 2014
    Missouri
    Gonna be tough on the Nissan parts are scarce. But several omc parts fit.
    No idea in yor area though but it’s a basic carb stator build any decent tech can work it.
    The 70 is bored out over the 50-60, I forget the omc props that fit but good selection available.
    Jul 2005
    NY
    What's wrong with it? What needs to be done/checked?
    '84 Checkmate Convincor twin v6 closed deck Evinrude loopers Heavily ported, finger ported pistons, 2.7 heads,drilled/relieved exhaust,148 psi comp, milled fingered vertex pistons
    CDI 8500 digital ignitions Boyesen reeds..And more....
    Sep 2011
    maryland
    ........what he said........they are actually pretty simple.........at least in quick diagnosing to narrow it down to more precise things.
    Jun 2004
    long island
    Both engines have been sitting a few years - so at least carb & water pump work would be expected
    I have no idea whats wrong with the power heads - possibly nothing
    I would like to see if they are worth running or if i should look for something newer
    i know the Evinrude needs the trim repaired & the shift shaft bolt in the pan is stripped (as per a friend who looked at it) so the lower unit cant be readily removed
    both engines need to be re-rigged to the boats
    I would start off with compression tests and go from there
    The mechanics that I do know are not interested in these old motors - especially since they aren't Mercs!
    The compression test is easy enough, but I really don't have the time.
    I also have a newer 90 Yamaha to use if these don't pan out
    but again - looking for someone to rig it
    Thanks for the reply
    Jan 2015
    Yeah, you need to find that "guy" as dealerships want nothing to do with 2 strokes.
    Maybe try facebook, they have a local classifieds section. Or craigslist locally.
    There used to be a bunch of independent mechanics in my area. How good they were or reliable??????
    Good luck.
    Feb 2014
    Missouri
    Unless broken the Nissan should fire right up. Cleaning never hurts, but as long as the gas was good and stored right. Would definitely hook up fresh gas though.
    The rude is a rude
    The powerhead thing was just informative should you ever need parts. Sometimes they won’t touch if they don’t know any cross reference.
    Thats just me reminiscing the 50b I had.
  1. Evinrude mechanic
    By Bgilman in forum Technical Discussion
    Last Post: 05-11-2016, 11:14 PM
  2. I need an Evinrude mechanic.
    By hugetime1 in forum General Boating Discussion
    Last Post: 09-11-2013, 09:16 AM
  3. Looking for a south Florida evinrude mechanic for my evinrude 225s
    By flatback in forum Technical Discussion
    Last Post: 07-10-2013, 10:25 PM
  4. Need an Evinrude engine mechanic near Atlanta, GA...
    By LeBron_Hill in forum Technical Discussion
    Last Post: 10-10-2010, 12:08 AM
  5. Evinrude mechanic Milwukee area?
    By smith411 in forum Technical Discussion
    Last Post: 09-18-2008, 04:13 PM
Spinelli Props
