Results 46 to 54 of 54
05-21-2020, 11:26 PM #46
I wouldn't weld on that skeg and if it's not ill handling adding tab to the skeg is just going to slow it down.
Baja170 liked this post
05-22-2020, 04:04 AM #47Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
05-22-2020, 01:58 PM #48
Hi Joe - when i do a quick check using "Tunnel Boat Design Program" software, using my STV model and 100lb driver and 115 optimax engine (no other details, sorry), i get top speed 74mph. maybe this helps? (naturally the results depend on actual setup, so used a 'middle-of-the-road' hull setup to get a 'quick' check on possible speeds).
05-22-2020, 02:48 PM #49The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...Kid's Nowadays...I'll Tell Ya...They Are Sooooo Smart...lol...
05-23-2020, 06:47 AM #50
Good job Joe. nice rig.
RockTeam Junk
05-23-2020, 10:08 AM #51
Sweet rig!
05-23-2020, 10:31 AM #52Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
Your model is very close. He clicked of four 80 mph passes this morning with a 31 Bblades Blaster at 6100. Remember this is now a 2.07 gear in place of the stock 2.33, the limiter is at 6250 instead of 5750, its a modified 15" midsection that can blow its breath, it is a small case, small skeg, and the motor is high. Bottom line is that I never thought it would have the capability that it does.
HydroSkreamin, mrichartz liked this post
05-23-2020, 11:01 AM #53
good job, Joe! sounds like we tested the same boat! i'm sure that if I input your actual hull weights and setup changes, that the TBDP would accurately align with your water results. Your hull design is very sensitive to setup, power and weights, especially at lower speeds. You're getting great performance of that engine!
David - WI liked this post
05-25-2020, 09:34 AM #54
Introducing www.phoneconnectionslimited.co.uk for lowest price on mobile phones
By zedkelly in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 08-01-2013, 08:42 PM -
Lowest ET ever run in Pro-gas
By speedy in forum Racer's HangoutReplies: 197Last Post: 03-09-2010, 10:24 PM -
lowest boat sales 40 yrs
By chynewalkr in forum The Scream And Fly LoungeReplies: 2Last Post: 06-26-2008, 04:39 PM -
OMC V6 - Jetting lowest cylinders up one or two sizes
By tcsmith315 in forum Technical DiscussionReplies: 8Last Post: 10-01-2003, 08:49 AM
