Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 69 of 69
  1. #61
    Feb 2014
    Missouri
    Speaking of the jets mains were 82 mids 80 and idle 90 92 stock can’t remember if the 46 is set up different. Need to look at a book checking something
  2. #62
    Sep 2017
    Ashland city tn
    Wh 46. no mids just mains and idle
  3. #63
    Feb 2014
    Missouri
    Yep gonna have to go with merc on the carb.
    Ment 80mph also above.
    My books kinda screwy the stock carb for the 200 has the bore jet 96 and the left lower screw 80ish and the idle something. Pretty sure thatís not what he has. And the 175 if stock was .60. So gotta go with merc on it. As my infos bad.
  4. #64
    Apr 2014
    nj
    I just bought this boat and have never run it . Im trying to figure out the health and want proper setup on this engine with the help of everyone here . Id also like to know if there are any cyl heads out there I can bolt on to raise compression
  5. #65
    Sep 2017
    Ashland city tn
    I think u can throw a set 150 heads to raise comp ,or just cut urs. We got many many guys here that can cut a head cheap
  6. #66
    Apr 2014
    nj
    Any experience with the 420 laser and what I can expect it to run with this 2.4 modded
    I know a little 'bout tha Laser too... my favorite (had several) that I had many, many years ago! "laser efi" injected BP with dual "opposed" cable steering....
    any pics of yours?
  7. #67
    TX......somewhere?
    have no clue with that one?.. 420 Ray?.. that's a rare bird I think... gotta say I've never been around one that's rigged and runnin'.. think its pretty heavy!.. like 13 ta 1400 lbs?
    sorry but no...
  8. #68
    Feb 2014
    Missouri
    Think you have to go to 225 heads not positive
    but 135-150 2.0 and 2.4 175-220 merc, mariner, force, mark, sea ray, Sears, sport jet, merc race, marithon, ect all run out of the 15221a5 endcap/head kit
    Should be a good supply of spares though.
  9. #69
    Apr 2014
    nj
    pulled port head off today I see zero cross hatch . Did leak down and come up with 12 to 18 % Pistons are standard bore .
ID:	440190   Click image for larger version.
ID:	440189   Click image for larger version.
ID:	440191   Click image for larger version.
  1. Looking for OMC Advice
    By Twozerofour in forum Technical Discussion
    Last Post: 07-30-2012, 09:27 PM
  2. Advice
    By too late in forum The Scream And Fly Lounge
    Last Post: 11-12-2009, 09:44 AM
  3. OMC Tech: would like advice
    By omcnut in forum Technical Discussion
    Last Post: 04-29-2009, 07:12 AM
  4. Set-up Advice Please
    By Oz Dude in forum Props, Setup, and Rigging
    Last Post: 01-05-2009, 11:22 PM
  5. Need some advice
    By Baja18 in forum General Boating Discussion
    Last Post: 03-13-2003, 11:44 AM
