Results 1 to 15 of 19
Thread: Progress
    NE Louisiana
    Progress
    FT Corsair. Wing is almost done. My hot glue gun sucks though!!!
  2. Likes Capt.Insane-o, SUNKIST, NICE PAIR liked this post
    Nov 2001
    Lake Charles, Louisiana
    Go buy a good one and get busy. We need to see the planes fly.
    93 STV Mod VP/MERC 2.5 200
    Proverbs 4:18-20
    -- John F. Kennedy 1962
  4. Likes Forkin' Crazy, NICE PAIR liked this post
  5. #3
    NE Louisiana
    Working on the fuse. I can't tell you how many times I have said ouch... Okay, I said F%^K!!!! That glue is HOT!!!
  6. Likes NICE PAIR, mrichartz liked this post
  7. #4
    NE Louisiana
    Wing is done. One of my RC buddies said a Corsair is hard to see... Dark blue.. Almost black. I think I have a fix for that...
    NE Louisiana
    Paint... and mods... Tribute!!!
  9. Likes mrichartz, CDave, NICE PAIR liked this post
  10. #6
    NE Louisiana
    Looks like $hit because I am a novice builder... I think I am going to paint it primer gray with white and black accents.
  11. Likes CDave, NICE PAIR liked this post
  12. #7
    8 Post(s)
    my mate in OZ has one, did a wheels up landing, fancy a repair job?
  13. #8
    Ft. Lauderdale, Fl
    Did one from a kit years ago, came out good..... have plans for a LazyBee.... going to super size it......
  14. #9
    NE Louisiana
    The ParkZone Sport Cub mods..
    Tundra tires from an FMS Kingfisher. A change to different prop hardware netted a drop in weight of almost 20 grams. This was reciprocating weight added to make it fly better and it was out on the nose. Which makes a big difference in CG (center of gravity). Pictures on CG stand with a larger battery full forward and it looks a slight nose down PERFECT.
    Film at eleven!!! I guess I need the go pro on my head?
  15. Likes NICE PAIR, CDave liked this post
  16. #10
    NE Louisiana
    I forgot to mention I went from the stock flexible 9X6 to an 11X7 APC that has a totally different profile and is composite. Picture before spinner/prop mod. The new set up will facilitate more airflow across the motor and ESC also.
  17. Likes NICE PAIR, sonicss33, CDave liked this post
  18. #11
    NE Louisiana
    The prop shaft is hard as a minister's D%^K!!!.... And now is broken... Quartering down wind landings... or flops..... Three nose overs and I get this... Hard was the last one!!!
    It rolls nicely... Snaps well. Loops accordingly.
    I have a "parts" plane.
  19. #12
    NE Louisiana
    Moving on to the build
    One thing cool about a build, you can do it how you want. One thing bad about a build, you might think you know what the f%^k you are doing.
    I glued in a part to mount the RX on.
  20. #13
    Ft. Lauderdale, Fl
    Quote Originally Posted by Forkin' Crazy View Post
    That shaft looks cast.....
  21. #14
    NE Louisiana
    Quote Originally Posted by flabum1017 View Post
    I had a 5" axle off a tractor that broke and had the same pattern. It is hardened steel.
  22. #15
    Nov 2001
    I've pulled a snapped axle in dump truck that look like that. Stupid driver learned what happens when you dump the clutch with a load.
    I forget the size of the truck but it was powered by a Cat 3208. Always loved that engine. I can honestly say I've never had to do any major work on one. They just run and run.
    Proverbs 4:18-20
  1. check my progress please.
    By N Wolf in forum Technical Discussion
    Last Post: 06-18-2014, 04:39 PM
  2. progress
    By boatermike in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-27-2010, 12:25 PM
  3. 15' skeeter progress
    By wetdreams in forum Props, Setup, and Rigging
    Last Post: 05-08-2009, 04:05 PM
  4. Progress
    By David in forum General Boating Discussion
    Last Post: 04-21-2007, 10:44 PM
  5. progress!!!!!!
    By ILLandowner in forum Props, Setup, and Rigging
    Last Post: 08-22-2005, 11:24 PM
