Results 1 to 3 of 3
    Mar 2009
    Lake Vermilion, MN
    Sportmaster vs Torquemaster 2
    I have a 2005 Hydrostream Voyager that has been going on a 2 year makeover. Originally had a 2005 250XS, it will now have a 225 Optimax powerhead, 20" XS mid section, and a New Sportmaster with 10 min of run time. I have read that it probably won't be needed and might even hurt me because I'm thinking upper 70's will be the max out of this rig. The 250 XS was good for low to mid 80's. With a 1 person prop 29 pitch I heard low 90's. So my question is, would I be better off getting a Torquemaster 2 for this? I have read they are not compatible do to the trim units, a relief issue? Are they physically the same? I have the trim motor in the boat. Thanks for the help!
    Feb 2014
    Missouri
    Sporties run on top the water with prop half out.
    If not running on top then torqy
    Mar 2009
    Lake Vermilion, MN
    Thanks Motv18, I do run it high.
  1. Sportmaster vs Torquemaster
    By aaronmt73 in forum Props, Setup, and Rigging
    Last Post: 10-10-2013, 06:08 PM
  2. Mercury Tech: torquemaster/sportmaster
    By danny3 in forum Technical Discussion
    Last Post: 04-11-2011, 08:54 AM
  3. Mercury Tech: Torquemaster - Sportmaster
    By stratos268v in forum Technical Discussion
    Last Post: 10-07-2009, 06:13 PM
  4. Sportmaster & Torquemaster?
    By NFA Avance 33 in forum Technical Discussion
    Last Post: 08-31-2005, 01:09 PM
