Results 31 to 45 of 45
Thread: v4 cross flow ignition
05-12-2019, 10:04 AM #31Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Yes something is out of round or bent or real sloppy.
05-13-2019, 04:47 AM #32Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
old crank with repair??
05-13-2019, 12:12 PM #33Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
Everything is new. rotating assembly dynamically balanced, upper bearing is new and there is no play in the crank.
I have measured the inner magnet outside diameter and the timer base inner diameter, and I agree it cant move that much.
I am not sure if the timer base is the issue or not but, every one I have pulled has had two opposite poles rubbed bright.
I replace the timer base and it will turn 7k for a bit then dumps to 6k and starts 4 stroking.
I appreciate all the input.
The MSD system is out of my price range, because of a claiming rule in our class.
Thanks again for all the input.
JimYou reap what you sow, corny but true.
05-13-2019, 12:50 PM #34Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Jim, you may have already done it this way.......and if so.........ignore me. Use a really good caliper or a mic to to check the magnets diameter.......in multiple spots. That way you can see if its just one area.............same thing for the timing base.
Long shot here.........but are all the grounds good? When I start scratching my head at something electrical, I will usually just check grounds......if it is required to make the circuit function. Unfortunately, I have not had to troubleshoot the timer base yet for all 6-7 motors that I have owned/built. So, that's all the further my advice can go with the troubleshooting.
05-13-2019, 01:06 PM #35Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
So no physical contact between parts while by hand turning assembly at full advance. No crank run-out, no flywheel issues.
05-13-2019, 07:36 PM #36Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
no sir
05-13-2019, 08:14 PM #37Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-14-2019, 08:45 AM #38Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
Not sure, but I am guessing it is going to be a voltage issue, as the motor runs fine under 6k. I believe I do not have adequate primary voltage at the higher rpm. I plan on testing it in the test tank with my stevens meter to verify voltage.
Thanks again Powerabout for your input.
06-13-2019, 06:08 AM #395000 RPM
- Aug 2009
- Florence SC
- 249
Year model engine ? Didn't understand your response on which ignition > 1 single pack for entire engine, or 1 pack for each bank.
Find you a v6 crossflow stator, 76-78, change brown/brown-yellow connections . this should pick up your low voltage side
06-13-2019, 08:28 AM #40Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
06-13-2019, 09:55 AM #41Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
I am running single pack. Spoke with CDI earlier and the suggested running a twin pack/dual charge coil stator and wiring them together to feed the single pack. I think I need to keep the color code the same.
Both brown to the brown and both brown/yellow to brown yellow, if I understood him correctly.
Or maybe take a 4 charge coil stator and feed two, two cylinder packs?
Thanks again for the input.
06-13-2019, 12:48 PM #42Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
Its a single pack sorry for the confusion.
06-17-2019, 03:26 PM #43Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Try using the older packs.............the 2 cylinder and stator to go with. 582125 is the unlimited powerpack part number for the 2cyl packs
06-17-2019, 08:36 PM #446000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
The glue has gone soft/ fractured on the flywheel. Centrifugal force is causing contact I assume the mag is polished as well where it hits.
So so probably need a reglue.
06-28-2019, 03:19 PM #45Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
Swapped everything to dual pack ignition, motor picked up rpm and runs clean.
Thanks for the suggestions it is really appreciated.
Thanks,You reap what you sow, corny but true.
keefallan liked this post
OMC Tech: V6 Cross flow 150 ignition options now that power pack is NLA
By 150aintenuff in forum Technical DiscussionReplies: 12Last Post: 10-02-2015, 07:51 PM -
OMC 175 cross flow
By Dogboy in forum Technical DiscussionReplies: 9Last Post: 06-24-2005, 06:30 AM -
Cross flow
By woody in forum Technical DiscussionReplies: 8Last Post: 06-07-2003, 10:25 PM -
Anybody Seen This On A Cross Flow?
By sixabove in forum Technical DiscussionReplies: 29Last Post: 03-16-2002, 07:39 PM
