Results 16 to 30 of 45
Thread: v4 cross flow ignition
05-10-2019, 10:22 PM #16Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
not seen a flywheel hub hit the sensor, sounds like there is some other issue?
keefallan liked this post
05-10-2019, 10:37 PM #176000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Check for crank play. It could be lose.
Never seen one hit either unless something was bent ir. Bearing shot.
Careful if you shave it don’t let any heat get it.
In fact if its its new enough send it back which ever is new
05-11-2019, 06:16 AM #185000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
Well my snowmobile kits range about 1000-1200$ depending on what's required. A v4 would be similar depending on what I have to do to make it work. The magnetic pickups on the flywheel would need to be replaced with a steel trigger plate. I have a v4 and a bunch of parts. I could start setting one up.
05-11-2019, 07:44 AM #19Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-11-2019, 08:46 AM #205000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
05-11-2019, 08:58 AM #21Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-11-2019, 09:46 AM #225000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
05-11-2019, 11:48 AM #23Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Throttle bodies, size? Injectors where?
05-11-2019, 01:01 PM #245000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
05-11-2019, 01:38 PM #25Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Going to put a xflow pan and cowl on an Etec and be done with it.
05-11-2019, 11:46 PM #26Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
05-12-2019, 06:08 AM #27Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
v8 and v6 aftermarket kit would be a seller i would think
05-12-2019, 06:14 AM #28
05-12-2019, 08:33 AM #29Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
What are the "short" comings of the OMC design?
05-12-2019, 09:32 AM #305000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
OMC Tech: V6 Cross flow 150 ignition options now that power pack is NLA
By 150aintenuff in forum Technical DiscussionReplies: 12Last Post: 10-02-2015, 07:51 PM -
OMC 175 cross flow
By Dogboy in forum Technical DiscussionReplies: 9Last Post: 06-24-2005, 06:30 AM -
Cross flow
By woody in forum Technical DiscussionReplies: 8Last Post: 06-07-2003, 10:25 PM -
Anybody Seen This On A Cross Flow?
By sixabove in forum Technical DiscussionReplies: 29Last Post: 03-16-2002, 07:39 PM
