Results 1 to 15 of 45
Thread: v4 cross flow ignition
05-07-2019, 12:20 PM #1Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
Has anyone tried an aftermarket capacitive discharge ignition and how did it work out. I am tired of changing triggers and power packs.
Thanks in Advance,You reap what you sow, corny but true.
05-07-2019, 02:14 PM #2Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
What are the parameters that you are running your motor? The reason I ask is this, I have never had any problems with my omc stuff in regards to that. I have a 115 with hot heads( never ran it that hard tho). Its a 96 year motor. I got it with a bad cylinder, rebuilt it and got 4 or 5 more years out of it. It has the original ignition on it.
I have more stories of my v6 crossflows........same thing......electronics have never failed me. Now, I did check resistances of the things that I could before I installed them. That way, I knew I had good parts. I am not saying that they don't fail..........they do. But I don't have a track record with bad stuff from OMC.
What is the scenario with your motor?
05-07-2019, 02:32 PM #3Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
Thanks for the reply.
When the motor gets to about 6k it starts 4 stroking and when I pull the plugs, 2 and 4 are wet. It has an unlimited pack so its not a limiter issue. when checking voltages the port side is low. all new electronics, trigger, stator and power pack are all new.
it will clean out every once and awhile and then it turns about 7k rpm
Thanks again
JimYou reap what you sow, corny but true.
05-07-2019, 03:53 PM #4Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
Are you using oem parts I switched to cdi and been real lucky just what I have experienced.
05-07-2019, 04:23 PM #5Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
At this point its all cdi. A lot of the OEM parts are now made by CDI.
05-09-2019, 10:10 AM #6Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
So I guess no one has tried any other ignition other than stock?
05-09-2019, 02:41 PM #7Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
There are others out there.....But i've come to discover that its a hush hush thing....just my opinion. I dunno why. The crossflows are dinosaurs and parts getting harder to get. I thought I remembered someone telling me they were using Yamaha electronics on their v6. But don't hold me to that. That was 3-4 years ago. You running the newer single powerpack with 4 leads or 2 powerpacks on each side?
05-09-2019, 04:11 PM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Some info here
https://www.screamandfly.com/showthr...tion+on+OMC+v4
05-09-2019, 05:32 PM #9Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Great read. Its got me thinking about modding my tuner for my 175...........sorry wrong thread, but that link hit as much exhaust info as electronics info.
FMP liked this post
05-09-2019, 07:17 PM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Just use the advanced search, Yamaha ignition OMC , titles. Lots of threads to wade through.
05-10-2019, 12:29 AM #115000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
I build programmable performance ignitions for snowmobile race engines. It's possible to do the same for the V4. I was going to do one for my own engine. Only problem is it won't work off the stock timing pick up system. So that would need to be changed.
05-10-2019, 10:07 AM #12Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
The problem I am having is the inner magnet on the flywheel hits the timer base pickups. It shorts the timer base and takes out the pack. When this happens the motor starts 4 stroking at or above 6000 rpm. Plugs on port side are wet after a race. I change pack and timer base and its good for 3 or 4 laps then starts over. If I can delete the stock timer base I think my problems would be solved.
Thanks for all the input.
05-10-2019, 01:07 PM #13Member
- Jul 2007
- Bay City, Texas
- 91
- 10
- 11
05-10-2019, 02:40 PM #14Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Can the magnet be milled down for clearance? Strange that factory stuff doesn't have the proper clearances..........are you running the factory flywheel?
05-10-2019, 02:53 PM #15Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Triggers, sensors , FI, maybe these folks could share some part numbers
http://www.aaenperformance.com/V4_racing_engine.asp
OMC Tech: V6 Cross flow 150 ignition options now that power pack is NLA
By 150aintenuff in forum Technical DiscussionReplies: 12Last Post: 10-02-2015, 07:51 PM -
OMC 175 cross flow
By Dogboy in forum Technical DiscussionReplies: 9Last Post: 06-24-2005, 06:30 AM -
Cross flow
By woody in forum Technical DiscussionReplies: 8Last Post: 06-07-2003, 10:25 PM -
Anybody Seen This On A Cross Flow?
By sixabove in forum Technical DiscussionReplies: 29Last Post: 03-16-2002, 07:39 PM
