Results 1 to 8 of 8
Thread: 1988 mercury blackmax 200 issue
05-07-2019, 09:52 AM #1Junior Member
- Jun 2018
- Massachusetts
- 10
So I'm just getting started again for the season and trying to remedy last years final run problem. Under load the boat really struggles to go (won't get on plane and wont rev to normal rpms). It sounds to me like its hitting a rev limiter or something. It only happens under load. I've attached a video so you can hear it. I had it at full throttle the entire video.
Does anyone have any ideas?
05-07-2019, 10:42 AM #2
Stator or switchboxes would be my first guess
LakeFever liked this post
05-07-2019, 12:42 PM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Switch box,
but one sound has had me guessing shift switch, the rod riding on it or bad. (More common with rudes the rod ridding the switch)
that said the way it catches going back to 6 says more switch box ignition stuff.
To me it also drops to many cylinders for carb, but fuel starved maybe. Never hurts to clean.
It sounding like my 3cyl sometimes pointed me to this'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
05-08-2019, 12:03 AM #4Junior Member
- Jun 2018
- Massachusetts
- 10
i cleaned the carbs, installed new fuel lines and oil lines after this video but have not run it yet. Will be running it this weekend to check. if its still doing it i will look into switchboxes. thank you.
06-05-2019, 10:33 AM #5Junior Member
- Jun 2018
- Massachusetts
- 10
PROBLEM SOLVED: got it checked out by a mechanic in naples maine (RPM service) found to be missing a screw on the carb linkage that was making it run on 4 cylinders instead of 6
06-06-2019, 01:47 AM #6
Start out with the easy stuff like pull the plugs and see if you have fire on each cylinder, and check the compression. Make sure your compression is within 10 % of each hole. If you have a bank out its probably going to be a switchbox but verify with a DVA meter the stator is sending the correct voltage.
06-06-2019, 04:24 PM #7
06-06-2019, 11:18 PM #8Junior Member
- Jun 2018
- Massachusetts
- 10
1988 Blackmax 150 XR2
By Msn26753 in forum Technical DiscussionReplies: 29Last Post: 07-04-2017, 06:37 PM -
1988 blackmax 200hp
By RICKY_ACTION_MARINE in forum Outboard EnginesReplies: 1Last Post: 05-19-2016, 12:13 PM -
1988 Mercury BlackMax 200 2.5 Outboard w/ low water pickup
By Captrudy in forum Outboard EnginesReplies: 6Last Post: 09-21-2015, 12:10 PM -
Mercury Tech: 1988 Mercury 200 blackmax WOT low rpm
By speedman79 in forum Technical DiscussionReplies: 34Last Post: 08-30-2015, 10:53 PM -
Mercury Tech: Charging Issue 1988 Mercury 150 v6
By mtlmndr in forum Technical DiscussionReplies: 0Last Post: 08-13-2011, 09:12 AM
