Results 1 to 15 of 17
    May 2019
    Norway
    I need a 120+miles etec
    So now when you know that i need a 120+miles etec, i guess you want to know why? I want a etec that can go as fast as any merc we got here. The boat does 106mph on a good day with a 200xs ros
    What is the fastest and cheapest way to get a 120miles etec? What do i have ? I got a 2008 250ho 3.4L, 20" mid and 1.71 gearhouse, and i got a 3.3L 225ho powerhead, but i also have a 15" mid to a 200xs ros, and a Sportsmaster but i need everything om the inside new, so i can build 1.5 gearratio or something like that (how low can i get to that House i have?)
    And its 1thing that is alittle boring with the etec's, its the rpm. I want 1000 more, what to do ? If i get 1000more rpm's i can use standar etec 20" mid and the 1.71 gearhouse with bobs nosecone kit. It would be funny to have norways fastest etec
    Its more than 1 solution to my problem, the easy and cheap solution, is to use the 300 ProMax i have. i want to see 100knots/115mph almost everytime i'm out driving, but i want to drive 300 hours a year, and then i guess etec is a better choice. If i dont use the 300pm on the blue, i'm going to use it on the yellow thats just going to be a sunshine boat and the Blue is a everyday racer
ID:	438109Click image for larger version.
ID:	438110Click image for larger version.
ID:	438111Click image for larger version.
ID:	438112 Click image for larger version.
    Attachment 438114
    Attachment 438115
    Attached Thumbnails Attached Thumbnails 20181130_130124.jpg.a07f1001be967e732d5e9977525fb043.jpg   post-12944-0-60276800-1540152965.png   20181020_114403.jpg
    Jan 2008
    SUMMERVILLE S.C.
    ETEC ...1:71 gr...6000 rpm..120 mph = about 40 pitch prop..don't see that happening
    May 2019
    Norway
  4. Likes FMP, David - WI, Will hedrick, keefallan liked this post
    May 2019
    Norway
    Anyone make a adapter i can have between the 2.5 15" merc mid and the etec powerhead? Anyone got drawings to a cnc driver ? If i put the driveshaft in the lathe, can i tig weld it or do i need to make a new? What kind of metal quality is the best way to go? How low gearratio can i get to the Sportsmaster to a 200xs ? How can i get more rpm's out of the etec? Can anyone "break" the emm and adjust the revlimiter or do i need a aftermarked ecu? the How much does a Taylor midsection cost ?
    Post more pics of that Yellow boat please.
    May 2019
    Norway
    The Blue and the yellow are both Twister 24, the white is a argo23
ID:	438145 Click image for larger version.
ID:	438146 Click image for larger version.
ID:	438147 Click image for larger version.
ID:	438148 Click image for larger version.
ID:	438149Click image for larger version.
ID:	438150 Click image for larger version.
ID:	438151 Click image for larger version.
ID:	438153 Click image for larger version.
    May 2019
    Norway
    Is the best solution 300xs, 1.62gr, dbr kit ?
  9. #8
    Bristol, WI
    3.4L etec at 7200 rpm w 1.71 or 1.62 w 34 cleaver. No problem. It's been done. Going EFI would make it much easier.
    Larry Gempp Jr.
    Lots of past boats - 2024 22 Liberator - 450R
  10. Likes g-guap liked this post
    The best solution is a 300R with a 1.60. Power, fuel economy, reliability, speed, and cool factor. Is there anything else that you are looking for?
  12. Likes Instigator liked this post
    May 2019
    Norway
    Quote Originally Posted by JPEROG View Post
    Yeah, i want the engine this year. Its 6months delivery time in norway on 300r
  14. #11
    May 2019
    Norway
    Quote Originally Posted by Speed Jr. View Post
    Is it some place i can buy the parts, or do i need to make them?
    May 2019
    Norway
    I have same boat as these guys, so i know its possible to go realy fast, if i get the right engine. But first i want a fast etec on the cockpitboat
    This is a old video of the yellow, with 200xs
    Same boat and engine
  16. #13
    May 2019
    Norway
    We going to make a adapter i can have between then 15" 200xs 2.5 midsection and the 3.4L powerhead, then we make a new driveshaft. Then i add a 300map and reprogram the injectiors to give some % more fuel. Then i have a okey and pretty fast engine this summer. 6200rpm, 1.62gr and 34", shold be funny enough the first summer
ID:	438717Click image for larger version.
  17. #14
    Bristol, WI
    Seems like your taking the hard route. Youd be better of getting a Jenkins mid setup with tall gear OMC or sporty if you want. Click image for larger version.
    Larry Gempp Jr.
  18. #15
    Australia
    That would be a smart move.
  19. Likes Speed Jr. liked this post
  1. Why are ETec G2 H.O. Motors selling for less than the older Etec H.O.'s ?
    By Pachanga_rick in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-05-2016, 01:51 AM
  2. Replies: 4
    Last Post: 01-29-2016, 07:19 AM
  3. Difference between 2008 etec 200ho & 2011 etec 200ho??
    By coojac in forum Racer's Hangout
    Last Post: 09-02-2013, 05:43 PM
  4. 700 miles later
    By paul folks in forum General Boating Discussion
    Last Post: 08-17-2009, 01:15 PM
