Results 1 to 2 of 2
    AZ
    98 250efi bleed line check valve alternatives?
    someone removed all the inline check valves on my 250 EFI motor. Seeking less expensive alternatives than $20-40 each...
    What if I don't put them back in? Harm anything? The original paint is on all the block fittings so I don't think any of those have changed.
    Help appreciated.
    Do you have any of the block or front half 90* fittings ?
  1. Bleed System Check Valve Replace
    By Glastron1987 in forum Technical Discussion
    Last Post: 12-09-2018, 08:39 PM
  2. Fuel Line/Bleed Line Routing for '96 2.5 200EFI
    By Hydrasports205 in forum Technical Discussion
    Last Post: 09-11-2017, 11:08 PM
  3. 2000+ optimax 3.0L bleed lines and check valve routing
    By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-06-2017, 08:36 PM
  4. Mercury Tech: 1979 150hp bleed lines and check valve flow directions ?
    By HarleyPHD in forum Technical Discussion
    Last Post: 08-23-2014, 09:42 PM
  5. bleed line check valves
    By dadgumit in forum Technical Discussion
    Last Post: 01-31-2009, 09:27 AM
