Results 1 to 15 of 21
05-05-2019, 10:33 AM #1
Prop Math - Do I have this right?
A boat with a 1.75 gear ratio LU traveling 6000 rpm with a 25p prop and 7% slip should get about 75 mph result?
6000 engine rpm / 1.75 = 3428 prop turns x (25"x.93) = 79701" water / 12" = 6641' traveled / 5280 (a mile) = 12.77 x 60 mph = 75 mph
Thanks in advance\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
05-05-2019, 11:11 AM #2Member
- Feb 2012
- Syracuse,NewYork
- 85
- 7
- 15
Yup, you're correct.
05-05-2019, 12:21 PM #3
05-05-2019, 07:57 PM #4
This works too
http://www.rbbi.com/folders/prop/propcalc.htmCheckmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
JBS thanked for this post
05-07-2019, 12:26 AM #56000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
either slip works though
slipping x mph off theory 76
or slipping x inches off pitch theory. 75
05-07-2019, 03:53 PM #66000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
JUST came back from some prop testing, 25''P, 6000 rpm 1.87gear[ i think] gps says 80, old type speedo says 88? doesnt seem correct. conditions were perfect, we were movin but 80? baffled now. 225 pm, trophy up high, bobs lower good pressure. cant seem to get rid of the torque steer, have tab, hyd steer wants to go right, big time, no fun. any answers welcome. my left arm aches!
05-07-2019, 03:56 PM #7Member
- Feb 2012
- Syracuse,NewYork
- 85
- 7
- 15
Gear ratio 1.75 I thought
05-07-2019, 03:57 PM #8Member
- Feb 2012
- Syracuse,NewYork
- 85
- 7
- 15
With a 1.75 that would be 1 percent slip
KIRCHNER thanked for this post
05-07-2019, 04:20 PM #96000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
05-07-2019, 04:23 PM #10Member
- Feb 2012
- Syracuse,NewYork
- 85
- 7
- 15
Yes
05-08-2019, 02:17 PM #11
How do you figure the slip?
An 88 2.4 fishing motor should have 1.87 gears?
A 200 pro max ECU has a limit of 7200?
05-09-2019, 04:38 AM #126000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
With the proper set up you can see positive slip. Cup and progressive pitch plus some jet like thrust from the tail
also pitch is theoretically figured unlike measured screw threads.
05-09-2019, 07:59 AM #13
What is this positive slip you speak of?? Never heard of that before. Please enlighten me.
05-09-2019, 08:26 AM #14
05-09-2019, 08:43 AM #15
If I use all the decimals I get the same result-
6000 /1.75 = 3428.57 x (25x.93) = 79714.25 /12 / 5280 = 1.2581 x 60 = 75.48
I was just rounding
Thank you for the short cut formula!Last edited by TraceF3; 05-09-2019 at 09:10 AM.
Who's a math wiz?
By Gorilla0178 in forum General Boating DiscussionReplies: 42Last Post: 12-16-2010, 05:06 PM -
MATH GU-RUs
By Jason Johnson in forum Technical DiscussionReplies: 20Last Post: 02-12-2009, 12:00 PM -
Prop pitch math
By gmjim in forum Technical DiscussionReplies: 0Last Post: 07-20-2008, 04:08 AM -
How about a little prop/gear ratio math?!
By mach351 in forum Technical DiscussionReplies: 2Last Post: 10-09-2007, 08:41 AM -
Please Do The Math..
By mr twister in forum Technical DiscussionReplies: 9Last Post: 04-15-2003, 08:37 AM
