Results 1 to 7 of 7
Thread: early analog BP efi question?
05-04-2019, 08:36 AM #1
drawin' a blank.. old depleted cells are failin' me.. how to and what numbers lookin' for with good/bad analog tps?.. anyone?
05-05-2019, 01:09 PM #2
The value when using the Merc tester says .74 idle and 1.50 wide open, no idea what those convert to in volts or ohms.
05-05-2019, 01:42 PM #3
which testor?.. assume they are sayin' one color ta ground?.. there is only two wires anda ground.. no adjustment with 'em so its either good or bad?
05-05-2019, 02:32 PM #4
You mean the vacuum style?
05-05-2019, 02:36 PM #5
yeah...
05-05-2019, 02:47 PM #6
I could never find a spec for those, the values I posted were for the mechanical one. Bet George Fuller would know. If you can't get an answer from him I could dig out my my motor and check what mine reads with 0 vacuum and hook a vacuum pump to it and see what it reads. It was working when I pulled it years ago.
05-05-2019, 02:53 PM #7
after he goes to tha lake with it will probably know if its workin' as it should.. seems ta be ok but that's ona hose!
Dave Strong liked this post
Question about 2.5 Analog ECU
By PORT in forum Technical DiscussionReplies: 11Last Post: 03-26-2018, 07:53 PM -
Ecu merc question analog vs digital
By pilotgmb in forum Technical DiscussionReplies: 3Last Post: 08-17-2013, 08:22 PM -
early 80s 2.4 150 fuel question
By toyomirage02 in forum Technical DiscussionReplies: 2Last Post: 09-16-2009, 04:26 PM -
2.4 EFI BP analog ECU question
By Carter Powell in forum Technical DiscussionReplies: 2Last Post: 06-07-2003, 09:26 PM -
Early EFI question
By Raceman in forum Technical DiscussionReplies: 5Last Post: 10-01-2001, 09:30 AM
