Results 1 to 14 of 14
05-01-2019, 02:46 PM #15000 RPM
- Jul 2008
- Canada
- 112
2002 Merc EFI 225 idling too high
Ok so I think I may have a bad TPS.
Symptoms
Idles at 1400 rpms on muff in neutral when warm and cold
Whats checked..
Thottle plate roller is alligned
Slight gap between the cam and roller
Throttle plate fully closed
TPS set at .96 volts
Throttle returns normall when hotfoot is pumped
WHat Ive done...
so if I unplug the tps while its running the rpms don't change and stay at 1400 rpms
If I disconnect the linkage and move the tps ahead the rpms pick up
If I let the tps go all the way back to 0 rpms don't go below 1400 rpms
Put new spark plugs in this year
Idles fairly smooth (for an efi)
Any ideas? I was doing alot of adjusting of the tps and throttle linkage as I just put this motor on this boat does the computer need to be run for some period before the idle will drop down? Maybe a bad TPS harness? Kinda lost on this one.
Oh the park plugs I am running are QL77JC4. I thought I was supposed to run QL77CC but I that's what was on the motor when I bought it and I thought I read somewhere these motors run better or the plugs last longer or something with the JC4 plugs.
05-01-2019, 03:14 PM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Ifvolts go up and are in range look for air leaks or timing issues.
05-01-2019, 03:24 PM #35000 RPM
- Jul 2008
- Canada
- 112
any ideas on how to check the timing when the rpms are too high? I have a timing light so I can test it but with the rpms too high not too sure. Will check for air leaks when it stops raining.
05-01-2019, 09:11 PM #46000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Should be able to check it cranking. Idle and max. While there you can check that none of the trigger is is jammed up or broken.
05-01-2019, 10:23 PM #5
This is a 3.0L correct?
05-02-2019, 10:04 AM #65000 RPM
- Jul 2008
- Canada
- 112
Yes 3.0
05-02-2019, 10:50 AM #75000 RPM
- Jul 2008
- Canada
- 112
05-02-2019, 12:01 PM #86000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Little tough to check
jumped without a serial number.
Still checksble just just have to make marks so probably to much.
Just no way to adjust. You can try adjusting the tps lower at idle. .96 is high even if below 1.0
might hit the cps with a blast of brake clean to clear any starter ring fillings.
How are the link rods looking.
05-02-2019, 12:06 PM #95000 RPM
- Jul 2008
- Canada
- 112
05-02-2019, 12:26 PM #105000 RPM
- Jul 2008
- Canada
- 112
Hmm, I cleaned the cps, verified clearance .040. When it’s cold isles at 1600 then drops to 1000, if I blip the throttle it dips to 600 rpms for an 1/8 of a second and picks back up to 1000
this is so annoiying. Lol
05-02-2019, 12:45 PM #115000 RPM
- Jul 2008
- Canada
- 112
Am I just chasing a red hearing? I haven’t run it yet in the water am I just reading high rpms because a lack of back pressure from not having the boat in the water? I have read the rpms can be 400-600 rpms higher on muffs than in the water?
05-02-2019, 02:39 PM #12
05-02-2019, 04:34 PM #136000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Possibly, newer ones will runaround 800
only thing I can see is is the tps rod end adjustment is tight at rest, unless you need it there to get 4.8v you can bring it in a turn or two. You can also give the map sensor a light tap, seats the seal and if it revs up generally good (iirc the tap checks for a broken board I always forget if it should rev or not for a good board)
Also noticed a lot of blue on one of the throttle plate screws. Has it been adjusted (roller looks good just curious) theirs an adjustment for the plate.
After that its normal or something not normally checked that has other symptoms'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
05-07-2019, 12:38 PM #145000 RPM
- Jul 2008
- Canada
- 112
Ok so just to close the loop on this I took it out yesterday and the idle came all the way down once in the water to 600rpm's Adjusted it up a bit and idles great. Now just need to adjust the throttle stop for wot. Forgot to adjust the Hot foot and was only getting 3/4 throttle. ran like a dog out of the hole and would only turn 5200 rpm's. I am actually surprised it even got up with how much the hot foot was out of adjustment.
96 mercury 200 efi idling to high
By Calvin1013 in forum Technical DiscussionReplies: 8Last Post: 10-22-2018, 04:48 PM -
Mercury Tech: 2.5 ProMax EFI idling high this year
By CHICKENHAWK in forum Technical DiscussionReplies: 12Last Post: 07-12-2018, 10:59 PM -
Merc 2.5 280 idling high
By NeedlesRat in forum Technical DiscussionReplies: 1Last Post: 06-30-2017, 09:42 PM -
1997 Mercury 200HP Offshore Edition Idling Too High
By MakoTom221 in forum Technical DiscussionReplies: 12Last Post: 07-06-2011, 08:09 AM -
300 X idling high
By Tom Foley in forum Technical DiscussionReplies: 1Last Post: 10-06-2007, 11:31 AM
